Happy New Year to all and may the Crazy Gods smile on your Rover! Now, I know this has been discussed elsewhere but can't seem to find it. Does anyone know the particulars for the NAPA oil filter that works with the spin-on adapter for 2.25 petrol engines? I like to support our hosts but also my local economy (12% unemployment). Thanks in advance.
napa oil filter
My spin-on filter adapters use the same filter that the Rover V8's use. At NAPA, I think it's a 1068. Purolator's is a 25195.
It's a mid-size, between a Fram PH8 and a PH16. (Those two are the same diameter, etc., have different lengths. The 8 is the big filter, the 16 is half the length. Either will interface, but lengthwise, the Rover filter is between the two, and needs an anti-drainback valve.... I'm not a fan of Frams, but it's useful to understand their sizes for cross-referencing...)-L
'72 SIII SW 88"
'60 SII 88" RHD -
I've had consistanly lousy experiences with Fram filters and consistantly good experiences with NAPA filters (I ask for a filter for a NAS D90); obviously I have a spin-on filter adapter.
Regards, Andrew
'63 SIIA 88" SWAndrew
'63 SIIA 88" SW
Rover Pics: http://www.flickr.com/photos/skunkal...7610584998247/Comment
the anti drain back or the anti back flow is a inner part of the filter. there's another thread here somewhere where i talk about putting my spin on adapter on backwards cuz i like the position of the gauge/light port. work fine for 2 years then along came a fram with an anti back flow valve and i did about 7 miles before the rod and main bearings siezed.'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
Which spin on oil filter adapter do you have? You can adapt a 2.25 using OEM parts from the 2.5l or you can buy that aftermarket hockey puck style adapter. I think the same filters can screw onto either of them but I've never used the 2.5's adapter.Comment
Out of curiosity-what filter does Rocky Mountain say to use with it?
See Sandy's post here:
I am using a Fram PH-8A equivalent Mobil1 filter, so I assume that's what the instructions said to use. I will check the instructions when I get home.
The photo on their site shows it with a Pennzoil PZ-7, which equates to a Fram PH43 - a smaller filter than the PH8A.Comment
mine has only one port but a tee allows for both the light and gauge. it's stamped "Top" and "Front" but like a potato head i didn't pay attention to that'64 Series IIA 88 Canvas Tilt
'76 Spitfire 1500
I don't know the difference either- I still use the old style filters on the 2.25s. I bought one of the puck style adapters from AB but it was crappy and I never got around to trying it out.
I'm tempted to try one of these:
NEW - Oil Filter Adapter Assembly
Convert your S111/2a to the later screw on filter type
£45.00
ERR 3340 - spare filter £ 5.45
But for that $ it can wait.
http://www.roversnorth.com/forums/at...4&d=1255616344
mine has only one port but a tee allows for both the light and gauge. it's got stamped "Top" and "Front" but like a potato head i didn't pay attention to that
Scott where did you get yours?Comment
I updated my earlier post - see above.Comment
