  • 4flattires
    • Aug 2007
    • 424
    I thought I was going to have a quick fix of the not-working-quite-right Smiths oil pressure gauge, which registers only 10psi. My swap meet special Stewart Warner gauge reads 80psi at idle, so I'm figuring a matching sending unit is in my future. Oh well, so much a for 5 minute fix.
    Jeff
    64 SIIa 109 all stock
    69 SIIa 88 all stock
    Old tractors
    New Harleys
    Old trucks
    • scott
      • 1226
      Jeff
      just take the average, 45 psi, that's pretty good
      '64 Series IIA 88 Canvas Tilt
      '68 Series IIA RHD Ambulance
      '76 Spitfire 1500
      • redmondrover
        • Nov 2007
        • 102
        Sound proofing
        Completed sound proofing the seat box. Applied fire-retardant expanding foam underneath and a combination of limp mass vinyl and 1/4 closed cell foam on the interior surfaces. Also applied the fire-retardant foam to the interior of one wing. Cleaning up the other wing this week to foam it.
        • 73series88
          • Oct 2009
          • 587
          wipers never worked
          switch was bad
          through a 5.00 toggle in
          i have wipers now.
          aaron
          67 series 2a 88 RHD sold
          88 RRC sold
          60 mga coupe
          • TJR
            • 279
            Stripped down the salisbury to the spindles ,contuniing to prep for the swap into my 88
            • masonater
              • Nov 2007
              • 329
              broke 2 of 3 exhaust studs off in the manifold, but i got one out! Also bead blasted my bump stops and mounts and they look brand new, i was pretty surprised considering how nasty they were
              1970 Series IIA 109 EX-MOD
              1971 Series IIA 109 EX-MOD
              1982 Mercedes 300TD
              1989 RRC
              1993 D110
              1994 RRC LWB
              1995 RRC LWB
              1995 RRC LWB
              1995 Disco
              1996 GMC 2500 Suburban
              1996 Disco
              1997 Disco
              2001 RR P38
              2005 LR3 HSE
              2006 RR HSE
              • NickDawson
                • Apr 2009
                • 707
                Had a great day with the rover!
                I fiddled with the timing to fix and idle and dieseling probelm - so far, so good
                I finished some electrical work, wired up my work lamp and rear defogger
                Somehow in the process of having the dash off I fixed the wipers, broke the ignition, posted here and got it all working again.
                Then I drove to the auto parts store and replaced the dead washer fluid pump
                Now I'm going back out to finally clean out the junk in the back
                • 4flattires
                  • Aug 2007
                  • 424
                  Today....I.....
                  Originally posted by NickDawson
                  Somehow in the process of having the dash off I fixed the wipers....
                  Same here, but when my dash was off fixing the oil pressure gauge, I fixed the fuel gauge!
                  I'm gonna leave my junk in the back for the time being!!
                  Jeff
                  Old tractors
                  New Harleys
                  Old trucks
                  • badvibes
                    • Mar 2007
                    • 364
                    Truck had started running roughly over the last couple of weeks. Occassional backfires etc. Changed fuel filter and messed with timing which helped a bit but didn't cure the problem. I've had distributor issues in the past so I broke down and bought a 45d last week to replace my tired 25d.
                    My bud scott came by yesterday to show off his repaired rear cross member and pintle mount and pick up his Sankey which I had. So we toss the new dizzy in, beer time it, and hit the road to go move some windows from his house to his brothers place.
                    Truck runs good to scott's place across town. We get the windows loaded in the Sankey on scott's 88. I'm following in my truck and we head for Terry's place. After a couple of blocks scott pulls over to check the tie downs on everything. While doing that my truck dies and won't restart. Change fuel filter, check gap on the points, try re-timing by ear, spray lots of carb cleaner thru the carb, and can't get my 88 to restart. Looking into the carb while turning the truck over I can see actual drops of gas in the carb, not a steady stream. So I think my old Rochester is the culprit now.
                    End up towing my 88 to Terry's and I'm going to call the local carb guru place to see about the Rochester. I did a rebuild kit a couple of years ago so it got new gaskets and stuff but not truly a "rebuild."
                    scott loaned me his 88 and offered me the use of his LR3 but honestly I've driven old iron for so long, my 88 is a '64 and my new truck is a '77, I'm intimidated by trucks that are smarter than me.....
                    1991 Range Rover Hunter
                    • Jim-ME
                      • 1379
                      After a week in Va. and driving a Prius down and back I'm happy to report that the Rover started like a champ and is running very well. I love a diesel engine!!! Next time I'm driving the Rover!
                      Jim
                      • SalemRover
                        • Aug 2007
                        • 310
                        Changed the fuel filter after having fuel starvation issues in my 2.5 transit diesel engine. 1 tsp of rust was sitting in the filter, and she ran fine after that. Inspected damage after having the rover sideswiped in my driveway by a ford ranger. Rover 1, Ranger 0.
                        • Terrys
                          • May 2007
                          • 1382
                          Out collecting sap with my '65 and notice the LF dragging a bit. Sat AM, before breakfast is even a concept, took off the drum. Wheel cylinder doesn't want to go back in. Compress with BA channelocks and it comes back out, so bleed a bit of air. Still no joy. Changed the hose which is looking well beyond it's sell-by date, and things are looking promising, but still a stiff spot. Pop the piston to see a nice rusty ridge.
                          2 out of 3 stones in the wheel cylinder hone look almost as bad as the cylinder, so call george for a new pair of cylinders. I hate when the fix means opening the wallet.
                            • 400
                            I just used the 109 pickup as a truck. Brought home one ton of wood pellets for the stove. Had fun driving thru knee deep melting snow to reach the stacking place on the front porch. I then picked up 31 boxes of floor tiles for the kitchen.
                            Truck ran great, but found the heater fan not working. I filled both fuel tanks and figured out i'm only getting 11.7 mpg with the Rochester carb.
                            '96 Disco SE7
                            '80 SIII 109
                            '75 SIII 88 V8
                            '68 SIIA 109 V8
                            • thixon
                              • 909
                              Last night I looked at it, and went over a list in my head of what I need to do to finish it. Two weeks off from work and it'd be done. I just can find the time.
                              1)test fit body
                              2)finish hydraulics and fill/bleed
                              3)finish driver side ball joint, and replace bearing/seal on driver side(both axles)
                              4)make brackets for bestop seats
                              5)finish bodywork (minimal), paint
                              6)re-assemble, and finish wiring
                              7)Done.
                              Travis
                              '66 IIa 88
                              • roverlandpark
                                • Feb 2009
                                • 38
                                I finished stripping the layers of military paint on the passenger side. Then I moved the Lightweight out of the garage and backed it in. Now I can start on the driver's side. Maybe this weekend I'll be able to add the Defender mirrors.
                                1979 Land Rover Half-Ton GS
