I adjusted the brakes on the QE I and found that the pedal travel is fine, but the brakes probably need new shoes all around. Tomorrow morning I load it up with straps and rope for the Maine Winter Romp.
I fired up the QM I for the first time in a few months. I took off the coil wire to clean up the corrosion inside the coil tip, and then hit the starter button without turning on the ignition. Once I saw some oil pressure, I tried to start the car. It took a shot of dry gas down the carb to get it running, but immediately, it smoothed right out. A tip of the cap to the original Solex carb.
I finished installing a new master cylinder by bench bleeding it, but there was a lot of air in the sytem. The brake bleeder screws are really corroded in place, so this is going to take a while.
Jeff
Jeff
