  • JimCT
    • 518
    #61
    winter romp
    We will be there, new Detroit locker and all
    1963 Unimog Radio box
    1995 LWB RR
    • Les Parker
      • May 2006
      • 2020
      #62
      Airportable being loaded
      So, the Airportable is on the way to its new owner :-
      Les Parker
      • KevinNY
        • 484
        #63
        This.
        • tmckeon88
          • 142
          #64
          What I did to the Rover this week...
          We installed new Pro Comp shocks on my IIA 88. The old shocks were rusting into bits, so it was time for them to go. It now rides just about exactly the same as before, but I feel better about it. I also found the reason my parking brake doesn't seem to be holding is the clevis pin had fallen out of the linkage and the lever wasn't connected to anything! New clevis pin, and we're back to a kinda-sorta parking brake. Also, after advice from Mike at RN and some other well wishers (including Jeff Aronson) I discovered the reason my fuel and temp gauges both suddenly quit is that their power wire came unplugged from the fuse box. Since I'm such an electrical genius that only took me about a month to sort out.
          The other Rover related advancement this week was taking my old slides from my Pan-American Highway trip in 2000 to the digital converter to get them put on a CD. It will be fun reminiscing about that trip. Alaska to Tierra del Fuego in a 69 Series IIA!
          Good wrenching, everyone.
          Tom
          Tom
          1969 Series IIA 88"
          • utahseries
            • Apr 2009
            • 155
            #65
            I finished rebuilding the rear axle assembly, thought I'm waiting on the truetrac and 24 spline axles from GBR. It's nice to have new bearings, seals, wheel cylinders, drums, shoes, pipes, and lines! (I just started the front axle).. I took my tank in to get it cleaned/coated, and I hung the springs.
            1956 86" S1
            1957 88" S1
            1967 109" SIIA NADA
            2007 LR3
            • CliftonRover
              • Mar 2007
              • 351
              #66
              built an exhaust for my disco, it was cracked and leaking but now it comes out the side of the rear fender above my custom bumper and I built a mount for my hellas on my front bumper getting ready for some night wheeling at romp.
              • gudjeon
                • 613
                #67
                Started the ser1, warmed it up. Drove to work. At the end of the day, started it up and drove home. I need to get it out to play.
                • vansdonk
                  • Oct 2008
                  • 72
                  #68
                  So Embarrassed
                  My new '70 Wagon has been down for a week due to the starter being bad. Finally got some time off work to drop that off for rebuild. Come home to find my mom had hung damp rugs all along the push bar in front to finish drying. I have got to get her out of the garage. The Rover not the mom.
                  Kristi
                  1969 Series IIa 109
                  1970 Series Wagon
                  1974 1/2 MGB
                  2004 Disco II-last of her kind
                  • rwollschlager
                    • Sep 2007
                    • 583
                    #69
                    Today I pulled the intake and exhaust manifold off for the 3rd time in two weeks. All of the gaskets in there are taking their turns blowing and leaking exhaust. By tomorow should have all new gaskets for the manifolds and carb installed.
                    -Rob
                    72 SIII 88
                    67 SIIA 109
                    82 SIII Stage 1 V8
                    • CliftonRover
                      • Mar 2007
                      • 351
                      #70
                      Rob is there something blocking your exhaust that is making the gaskets go bad?
                      • rwollschlager
                        • Sep 2007
                        • 583
                        #71
                        no its my fault completly. The first time i took them off was to replace all the gaskets, but i did not tighten the intake manifold to the exhaust manifold enough, so i started it up and it leaked worse than before i started the repairs.
                        At the time i couldnt figure it out and i needed to get to school so i just drove it, when i got there i noticed pieces of the gasket blown out, and the four brass nuts were loose. Lesson learned, and should be all fine and good tmrw.
                        72 SIII 88
                        67 SIIA 109
                        82 SIII Stage 1 V8
                        • Blueboy
                          • 153
                          #72
                          made sure the cover was snug.
                          gave a charge to the Optima.
                          Blueboy is in hibernation.
                          JT
                          One Life Live It
                          • rwollschlager
                            • Sep 2007
                            • 583
                            #73
                            today i finally wrapped up my persistent exhaust leak. The square gasket between the intake and the exhaust manifold was the culprit. Installed with new hard ware and some never-seize.
                            Stepped on the clutch pedal to take it for a spin and shorted out the headlight dimmer switch on the floor with some blue sparks (no... i was not wearing metal shoes lol). 1 30amp fuse later and its good to go. The 109 will be staring in a knock off movie of "man vs. wild" for my friends skit for our school's talent show. He's gonna win
                            -Rob
                            72 SIII 88
                            67 SIIA 109
                            82 SIII Stage 1 V8
                            • kevin-ct
                              • 309
                              #74
                              Just got my fan motor and heater core for my RRC. So, tomorrow the dash comes out and the fun will start!
                              Kevin
                              04 XJ8
                              92 RRC
                              02 Benz E320
                              95 RRC (sold 5/10)
                              72 Series 3 (sold 4/10)
                              70 Series 2A (sold 6/10)
                              Morgan +8 (sold 8/09)
                              90 Jetta (308k miles) (sold 5/11)
                              72 Triumph Stag (sold 1/08
                              • JimCT
                                • 518
                                #75
                                RR heater
                                I do not envy you, did that job on our 92 RR. Installed limb risers on the ambulance yesterday.
                                1995 LWB RR
