I just pulled apart the heater in My rover to figure out why I am not getting any heat. I blows hot for a while, and then luke warm after about an hour. I am also losing coolant down the rear of the front wheel well. What seems to be happening is as the coolant level drops, I lose the heat, and if I top up the radiator, I gain it back. There is some mild caked up coolant on the core, so it is leaking in a couple of areas.
Does anyone know of a replacement core that will fit that I can pick up at Napa? I don't think I am going to have time to have this one repaired prior to the winter romp. demensions are 8 X 10 X 2 3/8.
Whatever works for you.
