Ahhhh, can I just get a break for once? Got the heater matrix all in, started the rig, and the blower motor no longer works. apparently some crud losened up in there when I was moving it around to get the core in. Now for a new motor, and disassembly......again!
Kodiak MK III heater core
you sure its grounded?
It has a black grounding wire, and a second wire running to the switch. I tried powering it directly off the battery, nothing. It was working fine before I removed the unit, but I see a lot of crud built up around the coil, and I may have pulled the wire some with removal.
I read on here that a ford blower motor is the same. from a similar era vehicle. can anyone confirm this, or have you replaced your blower with something available locally?Bad gas mileage gets you to some of the greatest places on earth.Comment
