It seems like everyone has tried just about everything here. Has anyone done a mild nitrous system? Just enough to get you over that big ledge?
Nitrous
Yes, Nitrous comes in handy when you need that extra boost to get you up and over when rock crawling. As a matter of fact, I find that when in low range and using nitrous, my 40:1 ratio actually allows me to go 45mph! The engine does seem to get a little hot though, while continuously running above 6500rpm; but this is no serious problem as my 2.25 has been balanced and blueprinted.61 II 109" Pickup (Restomod, 350 small block, TR4050)
67 IIA 109" NADA Wagon (sold)
-I used to know everything there was to know about Land Rovers; then I joined the RN Bulletin Board. -
Could nitrus be a solution for those long vermont hills? Or is it for no more than 10 second bursts. I've seen setups where the nitrus is triggered only when floored, this might not be a good idea as I consistantly floor my 88". The engine is in good shape, i just drive fast.Comment
It might be better to think about your 2.25l as a nice tractor engine and your LR when so equipped as a REALLLY FAST 8n tractor.
They weren't geared or engineered with the thought of going very fast or traveling the US interstates. To do so you need to re-engineer a lot, a shot of nitrous isn't really going to accomplish that for you. Get a NP435 and 302 and a Sals rear axle if you want more power.Comment
Originally posted by Mike KochBefore altering your Series to boogie any faster than Solihull had in mind, please consider the condition of your brakes.
Mike Koch61 II 109" Pickup (Restomod, 350 small block, TR4050)
Not faster....
This has nothing to do with speed. It has to do with momentary HP. Our fully loaded ambulance/camper is fine on teh road, we just take our time, and fine 99% of the time off-road, but every so often there is a situation off-road that coudl use a bit more guts. Seems a tiny shot of nitrous might be easier than lower gears, bigger engines...and all that. I really am talking about probably a second or two of boost.1968 battlefield ambulance/camper
1963 Unimog Radio box
1995 LWB RRComment
Jim,
What other mods have you done to your engine so far? Nitrous would be the last thing I'd try, I think I'd even consider a turbo before Nitrous.Comment
other mods.
Took off the military fan, use an electric fan most of the time, electronic ignition, Weber non-progressive 38/38 carb with K&N air filter, pierce manifold, less restrictive exhaust, Mobil ! in the engine and Red Line in the rest. 255/85-16 Truxus tires.1968 battlefield ambulance/camper
1995 LWB RRComment
The goal should be enough reliable power to allow you to drive where you wish without over stressing the engine.
Personally I thought it was exciting when the engine ran out of power and ground to a stop when doing a steep technical climb in low range first. Especially when I could not see much of the trail behind me because of the high window placement of a lift gate. I got to rely upon the legendary effectiveness of 109 brakes in a steep uphill location. Ah, the adrenalin rush.
I don't get that adrenalin rush so much anymore with front disc brakes and a nice-
I think you've maxed out the real potential, a cam and some head work might be beneficial but $ for $ to get any extreme improvement you are going to be headed towards a different engine.
Disc brakes are great unless you happen to stall and lose vacuum. That is the only situation I've ever been in where I had an issue with them. 109 drums wouldn't have been much better in that situation I expect...
With discs I think a vacuum reservoir is a really good idea.Last edited by yorker; 03-17-2007, 01:45 PM.Comment
my 2.25 has no problem whatsoever with the long VT hills. Is that unusual?'67 sort of station wagon (limestone), '65 gray hardtop, '63 blue Station Wagon, '64 limestone station wagon in piecesComment
No, you drive an 88, I'd guess you are probably 600-1000lbs lighter than a well loaded ambulance. At least if you consider Jared Ivy's(kingslug) ambulance's weight.
A good 2.25 should do OK in an 88.Comment
