Hi all,
Finally got the main shaft nut off. I had to use a Dremel with a metal cutting bit to cut almost all the way through. So now I'm re-assembling.
I assume the tabs on locking washer face forward (the pre-bent ones). And then when everything is tight, you turn the flat tabs down and into the nut to secure it?
Anything else special I should do during re-assembly?
Thank you
Chris
Thank you
Chris
