Has anyone installed the 200TDI engine kit offered from Rover resource in CT?
200 TDI from Rover Resource
Maybe I'm a little dense, but WHY would you want a 200Tdi with no turbo on it...for Nearly $3k ?? If you just want a strong little diesel engine with no turbo on it, go buy a half dozen 2.5 diesels for that much money. Or.... do some research on the Cummins B3.3T that is gaining some serious fans in the Land Cruiser community.Comment
i think i talk w/ this guys and he was willing to include the turbo at no extra charge. he sell's 'em w/o for those who don't want to hassle with the fit issues of the disco 200tdi in a series lhd.Maybe I'm a little dense, but WHY would you want a 200Tdi with no turbo on it...for Nearly $3k ?? If you just want a strong little diesel engine with no turbo on it, go buy a half dozen 2.5 diesels for that much money. Or.... do some research on the Cummins B3.3T that is gaining some serious fans in the Land Cruiser community.'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
I was kind of wondering the same thing. I know that not everybody wants to have to get too creative in installing a powerplant, but eliminating the turbo takes away 1/2 of the benefit of having a 200Tdi in the first place (the "direct injection" part is the only other real advantage).
A half-dozen 2.5s would be strong. A single one...not so much. Perhaps you mean "tough" or "rugged"?? In that case, I'm with you all the way!
why waste your time with a 200TDI when you could do it proper and go with a 4bt or a 6bt. You will of course need some better axles, transmission, and possibly transfer case...but this is a small issue.
It sounds like none of these guys have any experience with the 200 NA.
I've heard is should be a very easy switch but not having done it, I can't give you a list of things to check/do. The turbo variant does have major fitting issues if it's a disco 200tdi. If it's a defender 200tdi, then I believe the relocated turbo will solve your trouble.
Do you have a specific question that needs answering?Comment
FWIW Glencoyne was one of the major proponents for the 200Di:
defiantly more torque and omitting the turbo from an engine built to handle one means it'll run for ever w/ just oil changes. what does the 2.25 and the 2.5 dzl get in the way of mileage? the 200 di is supposed to be in the mid 20s, isn't it? i'm going w/ the 200tdi when i hit the lotto but mines a rhd so even the disco set up is suppose to be an easy fit'64 Series IIA 88 Canvas Tilt
'76 Spitfire 1500
