A fe Questions
  • albersj51
    • May 2010
    • 687
    A fe Questions
    I figured I'd get some questions out of the way in a single post:
    1. The Series IIA Workshop Manual CD-ROM...Any good? Does it have everything a newbie, like myself, will need?
    2. Below is a pic of my driver side rear wheel. I noticed it looks oily, now that it sat for a couple of days I see a brownish puddle on the outside rim lip. Am I correct in assuming I need to replace the hub seals? Anything else it is likely to be? Is there anything needed other than new seals? Want to make sure I order everything up-front.
    3. Anyone know where I should look for a used, or reasonably priced new, 88" Hood Stick Set? No offense to our hosts, but $1,000 for the frame and canvas top is a little more than I'd like to spend.
    Thank you, as always!
    J
  • czenkov
    • Sep 2008
    • 148
    Those are seriously hard to come by. But they pop up now and then. $1000? Actually not bad from the prices I see for used out there.
    1960 88" SII Pliny the Elder
    1997 D-90
    "Fear profits man, nothing"
    • bkreutz
      • Apr 2010
      • 408
      I believe the CD version is the same as the paper workshop manual, I just prefer to have something in my hand while working on it. (maybe I'm just from the older generation). Regarding your leak, is there grease/oil/brake fluid on the inside of the wheel? Could be a number of things, if it's just on the outside I'd suspect the gasket on the drive flange or the fit of the little cap over the end of the axle. I try to take the thing apart first because it seems that the one thing I don't order is the part I need.
      Gale Breitkreutz
      '03 Disco
      '47 CJ2A
      • crankin
        • Jul 2008
        • 696
        I just recently learned that if the axle breather is dirty/clogged that it will cause that puddle.
        Birmabright Brotherhood
        Clint Rankin - 1972 SIII SWB
        • albersj51
          • May 2010
          • 687
          Czenkov: Yeah, I'm having a hell of a time trying to find them...I've thought about going to the UK where they're a lot cheaper, but I think shipping will make it less cost effective.
          bkreutz: I plan on printing the entire manual and putting it in a binder so I have a hardcopy of it. Nothing in the wheel well that I can see. I looked really closely at the cap and I see a slight drip between the plate behind the cap and the rest of the axel, so I think you're right its the gasket on the drive flange.
          crankin: I'll check/clean that while I am in there. Thanks for the tip!
          Thank you all for the help! Any other info is greatly appreciated!
          J
          • mongoswede
            • May 2010
            • 757
            by "hood stick set" are you refering to a soft top canvas and supports?
            • albersj51
              • May 2010
              • 687
              Yep! I may have the terminology wrong, but thats what it was referred to as on a British site. Hood Stick Set meaning the Canvas top frame.
              • Jim-ME
                • 1379
                The workshop CD is print protected so you can't print it off. Otherwise it is the same as the green bible.
                Jim
                • mongoswede
                  • May 2010
                  • 757
                  Jim
                  there is always the "print screen" trick.
                  • luckyjoe
                    • 335
                    The "old" versions (WSM, optional parts catalog, SII, SIII, Military, etc...) are available on the web in PDF format. They print fine. Old truck = old manual = perfect!
                    I do own an all-in-one version of the Green Bible, but in the garage I find that printing an exploded view and taping it to a piece of cardboard is much more convenient. I mainly use my GB for study prior to the job...
                    Regards,
                    Tom P.
                    1965 exMoD 109
                    1995 RRC LWB w/EAS
                    • Jim-ME
                      • 1379
                      The print screen trick never worked for me which is why I sold the CD and use the green bible exclusively. FWIW in my case the CD was a waste of money.
                      Jim
                      • mongoswede
                        • May 2010
                        • 757
                        Jim
                        well its 1) "print screen"
                        2) paste and edit into Paint.
                        • Jim-ME
                          • 1379
                          So happy you shared that. It's much easier to read the book.
                          Jim
                          • mongoswede
                            • May 2010
                            • 757
                            Of course I am in no way endorsing the piracy of copyright protected materials....yada yada eplurbum unimum battlestar galactica.
                            • albersj51
                              • May 2010
                              • 687
                              Thanks everyone! Definitely glad i asked! Sounds like the CD won't work for me.
                              I read a post where someone recommended using Right Stuff sealer/gasket maker instead of a flange seal and felt washer...any one think that's good/bad/indifferent?
                              Also the oil dripping out is that gear oil from the rear differential or is there oil in the hubs? Thank!
                              J
