shock absorber bushings, whats the trick?
  • NickDawson
    • Apr 2009
    • 707
    Im on my third shock and its not getting easier, so I am hoping there is something I am missing.
    I'm putting on new ProComps - they have two bushings that compress together. The top is easy enough because it is a bolt.
    The bottom is just a massive washer and cotter pin. Try as I might, I cannot find a good way to get enough compression on there to even get close for the cotter pint to slide in.
    I've got 'em lubed up with dish soap, I've tried clamps (but theres not much to clamp to), vice grips... the works.
    What am I missing? (besides a cold beer)?
  • bkreutz
    • Apr 2010
    • 408
    Find an old socket that you don't want, big enough to catch the washer, then cut a couple of slots in the socket, then you can use a big clamp to compress the washer (and the bushings) then slide the cotter pin through the slots in the socket.
    Gale Breitkreutz
    '03 Disco
    '47 CJ2A
    • NickDawson
      • Apr 2009
      • 707
      Clever! And clearly something that warrants purchasing the drill press that I've been coveting (although thats a ways off in the budget, may have to try with a hand drill and vice)
        • 378
        Sockets are a hard metaland don't drill well. It might be faster and easier to grind slots with an angle grinder.
        • NickDawson
          • Apr 2009
          • 707
          does anyone make a specialized tool for this? Seems easier than grinding slots in an old socket.
            I'll make you one for $83.50 (price using an old SAE-sized socket--If you want me to use a metric socket, that'll be $94.05 If you need it in witworth, that'll be $475.22).
              • 378
              I was able to squeeze the washer in just enough on just one side to start the pin into the hole. After the pin was in as far as it would go, I squeezed the other side..... The socket idea is a better way.
              • gudjeon
                • 613
                Big water pump pliers. Squeeze to get pin started. Squeeze other side and push pin through.
                • yorker
                  • 1635
                  That is how I did it too.
                  Land Rover UK Forums
