Purely to be able to remove all the rust. I'd rather only disassemble the clutch pedal tower this once.
That did occur to me. I also discovered some paint peeling & discoloration on part of the bulkhead from the exhaust, so something is definitely needed. Was going to start w/some exhaust wrap.
You mentioned much earlier that the exhaust downpipe was extremely close to the slave cylinder. The thought occurred to me that your problems might be due to that very reason, you might be boiling the fluid. Did the problems occur more after a good drive than a short trip around the corner? If so rigging a heat shield may be in order when you get it back together.
