painting serIIa
  • woodman1
    • May 2010
    • 37
    painting serIIa
    I have a 1963 serIIa 88. It's poppy red. Has anyone had a rover painted lately?I'm in so. ca.
    thanks
  • gambrinus
    • 142
    Get the paint codes and go shopping. Painting a rover isn't any different than painting anything else as long as you don't strip it down to the bare birmabright... just sand and paint like anything else.
    • Bertha
      • Nov 2007
      • 384
      You will need:
      paint stripper
      an expoxy primer/etch primer
      a 2k high build primer
      and the paint you choose either single stage or base/ clear
      I like Dupont paints for Rovers as I have found there color match to the original is really good. I also like their Variprime, epoxy primer, product. It sticks really well to aluminum
      go easy with any sanding (try to paint strip as much as you can)and dont use sand paper that is coarser(a word?) than 180 grit. Aluminum is soft and distorts easily. Also be mindful if you are fixing dents with filler as aluminum and filler dont work well together in large quantities.
      If you have any specific questions, please post them.
      1971 88 (restored and as new)
      1967 88 (the next project)
      • thixon
        • 909
        To add to Bertha's post:
        If you use the body filler, you can scuff up the aluminum with coarse sand paper (I don't recommend this option) to get it to stick. Or, you can epoxy prime, and then add filler (I do recomend this option) over the primer. Make sure to read the directions on the can of epoxy primer you buy. If you let an epoxy primer harden long enough, you have to sand before coating it.
        Travis
        '66 IIa 88
        • KevinNY
          • 484
          or you can just paint over the dents like me
          • mongoswede
            • May 2010
            • 757
            a few alternatives:
            Paint Your Car With Rustoleum: Do you have a fun car that you just KNOW will go faster with a brand new paint job?This method is based on the idea of using a foam paint roller to put many layers of Rustoleum on your car. Except, I used a professional airgun and only 2 coats. The …
            • thixon
              • 909
              I have been involved in a rustoleum spray jobs in the past. Ace hardware will actually custom tint the stuff. If came out okay. A major downside is that it took FOREVER to dry. A 2k will harden quick, and last longer as well. Just depends what you want.
              painting the car with a roller seems like it would be more trouble than anything else. You'd be better off just using a bunch of buzz bombs of krylon from lowes/homedepot/menards/ace/whoever.
              Travis
              '66 IIa 88
              • Andrew IIA
                • Feb 2008
                • 327
                I'm with kevinny; paint over the dents if you must paint it. I'm just letting mine fade
                Andrew
                '63 SIIA 88" SW
                • mongoswede
                  • May 2010
                  • 757
                  There was a good website dedicated to roller painting and some of the projects they did were amazing. But it still takes a lot of time and effort to make it look good. The roller painting will be cheap in out of pocket expense but expensive in personal labor.
                  • thixon
                    • 909
                    Yeah, that's what I was getting at. In terms of getting paint onto the truck, it could be done with a roller. But with all the angles and seams and such, it would be bear to get it looking right. I don't even want to get into the coating/sanding/coating/sanding you'd have to do.
                    Travis
                    '66 IIa 88
                    • mrdoiron
                      • Dec 2009
                      • 446
                      Here is another reference on painting :
                      mike
                      1961 Ser IIa Hybrid Defender
                      1969 Ser IIa Bugeye
                      1998 Disco - ex wife :-(
                      2010 RR Sport Supercharged
                      http://mikerovers.shutterfly.com/
