Good price on axles, but not for installation into your rover.
While I'm sure you are oogling over a Dana 60, the fact of the matter is that stock Dana 60s aren't that much stronger than a Dana 44. The 44 and the 60 both have the same axle shaft size. Also there is a possibility that the Dana 60 you are looking at is semi-float, making it less desirable.
However the front Dana 44 is desirable for jeepers. You could probably pick it up for $100 and then sell it for ~$300. Maybe more if you painted it and cleaned it up. Also assuming said axle isn't all shot to crap (I.E. good gears, good carrier, good shafts, etc).
