Just remember the energy from hitting something goes somewhere. Too stiff a bumper and you end up bending the frame.
It can be substantially thicker and still bend before the frame.
I think rover knew what they were doing.
they might have, but production vehicles are the result of engineers AND accountants . . .the stock bumper, just like the retention of the ten spline axle, deletion of galvanizing on the chassis and door frames and many other features was a cost cutting measure. FWIW a HD bumper produced by Mayflower Winches (later fairey winches ltd) was an approved rover accessory.
Get a full bumper replacement. That is what I did and there are so many benefits it is worth it. I know there are numerous ones available out there so plenty to choose from.
I'll plug for ARB. I've got a defender ARB on the front of my 109. It is
I do not know how you set the valves without the hand crank, it makes it so much easier. If at all possible figure a way to mount the winch and still use the hand crank. And you can start your rover with the handle if you have to, not a bad back-up.
1963 Unimog Radio box
1995 LWB RR
