Tire recomendations
  • mike_cyul
    • Aug 2010
    • 17
    Tire recomendations
    Is anyone out there stilll using 7.00 - 16 tires, and if so, where are you getting them from? Or are there better alternatives?
    These would be for a 1960 Series II.
    Thanks!
    Mike
    1960 88" 2.25 Petrol LHD Export
    http://1960landroverrestoration.blogspot.com/
  • roverjohn
    • Nov 2008
    • 54
    How about some 7.50X16 ? We still have a few sets available.
    • osajaj
      • Mar 2010
      • 103
      Recommendations for 15" rims on a series 2a 88 with stock suspension. I think 235/85/15 may be a little to big for what I am looking for. Any suggestions? Want to keep it fairly stock/skinny.
      1996 Discovery SE7 5spd -SOLD
      1962 Series 2a 88"
      • jac04
        • 1884
        ^^ I don't think you are going to be able to find a 235/85/15 tire.
        • osajaj
          • Mar 2010
          • 103
          I actually found a set, i am pretty sure, if i remember correctly. They are BFG ATs. They come in a multitude of sizes. But not sure if I want to go 32, 31, or 30 size. Any thoughts?
          1962 Series 2a 88"
          • Blueboy
            • 153
            possibly LT235/75R15/C might be what you found for the BFG AT?
            Jaime
            One Life Live It
            • LR Max
              • Feb 2010
              • 315
              What are you doing with the truck? Mix of whatever? Mainly off roading? What part of the country are you in?
              If you are purely street pounding, then Dunlop Radial Rover A/Ts are pretty good. Good ride and cheap.
              If you are mixing but don't want aggressive tires, the BFG A/T is really hard to beat. Good street manners, lasts a long time and a little aggressive in the woods.
              since you want to stick to a smaller size, I take it there is no reason to talk about any off road tire.
              235/75/15 is a good size. I think you'll be happy with them.
              • osajaj
                • Mar 2010
                • 103
                Sounds good.I live in RI, so normal new england driving. Mostly road driving, maybe light dirt roads. What is the diameter of 235/75/15? Sounds like those are my best fit. Thanks for the help. Also, anyone going to all metal dash, I saw a post on here somewhere.
                1962 Series 2a 88"
                • LR Max
                  • Feb 2010
                  • 315
                  Dunno about the BFG A/T (someone else can chime in) but the Dunlop A/T works fairly well in foul weather...well, the foul weather that the south gets. They performed fairly well on the ice.
                  235/75/15 is roughly 29" tall and about 9" wide. It is highly similar in side to the 235/70/16 on Disco 1s.
                  FYI, the 235/75/15 is a common size for 2WD half ton pickup trucks so you should be able to find them.
                  Lastly, make sure you get LT rated tires, not P rated!!! They are a little tougher which is probably a good thing.
