The other day my 109 began to stutter, then a mile from home quit entirely and would not re-start. I traced it to a faulty distributor rotor, and replaced it and the points/condensor/cap/plug wires as well. I've been wanting a Pertronix for awhile so I went and got one.
Now the Pertronix is installed, and I can start the motor, but I can't seem to get it to run smoothly. It's backfiring through the carb at times & out the tailpipe when I throttle up, and I have no power under load. Yes, I know I should play with the advance/retard, and have done so. The symptoms persist through the range of adjustment (to much either way, of course, and the motor won't start). I adjusted the mixture screw on my Rochester without much effect.
Any ideas? Anyone encouter problems with a Pertronix install? Particularly those of you running a Rochester.
