hole in my fender, for heater?
  • Rich Lambert
    • Aug 2009
    • 18
    #16
    After looking at the link on TeriAnn's web site, it would appear I've got a Kodiak Mark I. I do seem to recall that the PO mentioned something about my truck being from Canada.
    Rich
    '58 Series II 88"
    • albersj51
      • May 2010
      • 687
      #17
      If i remember Ikes site correctly, the Kodiak MKI is very rare.
      • lrdukdog
        • 321
        #18
        Hole in fender
        Originally posted by TeriAnn
        Don't I at least get an E for effort even if you don't think it is real??
        http://www.expeditionlandrover.info/Kodiak_heater.htm
        TAW you get an A+ in my book!!!
        Jim Wolf
        • gudjeon
          • 613
          #19
          I do recall a metal plate on Kodiak units stating the manufacturing by the Eaton Corporation of Canada.
          • Eric W S
            • 609
            #20
            No. I don't believe in the whole E thing.
            • TeriAnn
              • 1087
              #21
              Originally posted by Rich Lambert
              My '58 has the same hole. Here's a shot of the heater that was in it. I don't know what make it is.
              Hey Rich, Did you take these pictures? And if yes, may I have your permission to use them on the Kodiak page of my web site?
              Here's a thought for the original posting to this thread.
              Since the Kodiak heater was a North America dealer installed option, could the truck have been delivered from the factory with a shin burner heater and the original owner opted to buy the optional Kodiak heater? It would certainly explain 2 sets of heater holes. The factory interior upholstery would cover the extra bulkhead holes as I'm sure the dealer also put plugs in them as well. Or it could be the owner bought it with the stock LR heater and came back after the first really cold days wanting a heater upgrade.
              Teriann Wakeman_________
              Flagstaff, AZ.
              My Land Rover web site
              • J.McKelvey
                • Jan 2010
                • 91
                #22
                I thought some rovers came with heaters like that. After that model they went to the more popular (and more common) model.
                I haven't seen one in that good of shape! Usually they are rusted out. The last one I saw had dryer hose wraped around it.
                John
                1951 I 80" - Summer driver
                1965 IIA 88" - Daily driver
                1964 IIA 109" - Future project...
                • TeriAnn
                  • 1087
                  #23
                  Kodiaks were a North American dealer option. Kodiaks were not installed at the factory, but in the dealer's shoppe. Which accounts for a lot of slight variations in instillation. The Land Rover FAQ web site has Jpegs of the Kodiak MKIII instillation instructions (linked to from my Kodiak page).
                  So far I really don't have anything on the MK I and MK II.
                  Flagstaff, AZ.
                  • JohnOFromJersey
                    • Nov 2007
                    • 11
                    #24
                    Did any of these Kodiaks (or any other heaters) ever attempt to heat recirculated air??? I have the standard Smiths and it seems to me the limiting factor is that it's always trying to heat fresh (possibly very cold) air thus making the job that much harder. (Not that I'm against fresh air or anything ;-)). Just wondering if there's a more efficient way.
                    JO
                    • TeriAnn
                      • 1087
                      #25
                      No the Kodiaks don't do recycled air. The best they can do is restrict the amount of cold air coming in.
                      I modified my MKIII intake the old fashion way. I replaced the intake hose with a plastic pipe 'T' from my local hardware store and cut a hole in my bulkhead to fit the bottom of the T to go through. Being decidedly low tech, I just have a plug that I place at the bottom of the 'T' in the summer half of the year to revert the heater to fresh air only so I can chase away cool night temps. Then place on the end the goes out the side of the wing for the winter half of the year to maximize heat by making the Kodiak a recycling heater. A thing to remember is that recirculating air maximizes dew on the inside surfaces including inside of the windscreen when it is raining and water has leaked in through the super effective Series door seals. cold air drawn in from the outside tends to be less humid than warm interior air when the floors are wet. Recirculating air can be a double sided sword in a cold rain storm but is a big plus when it is cold and not raining.
                      I'm sure someone who was handy at plastic fabrication could adapt the Kodiak input flapper to the plastic piping 'T' so it could use the stock vent lever to change between recycling and fresh air. I tossed those parts about 30 years ago to try and get more air flow. It didn't help.
                      Flagstaff, AZ.
                      • Rich Lambert
                        • Aug 2009
                        • 18
                        #26
                        Yes, and absolutely...let me know if you need any detail shots.
                        Rich
                        '58 Series II 88"
                        • yorker
                          • 1635
                          #27
                          JO
                          Fresh cold air when heated = dry air, that is why they do that. Same reason why the AC kicks on with modern defrosters. Otherwise over time you start blowing warm moist air on the cold windows etc. If you are having problems with it you might need to look at your seals (door and otherwise) or a new heater core or perhaps even the double heater core mod.
                          Land Rover UK Forums
                          • TeriAnn
                            • 1087
                            #28
                            THANK YOU.
                            if you could two close up shot of each of the parts from different sides would be absolutely super.
                            THANKS
                            Flagstaff, AZ.
                            • J.McKelvey
                              • Jan 2010
                              • 91
                              #29
                              Sorry, I didn't mean to apply that they came from the factory with Kodiaks but just in general most Canadian rovers came with them from the dealer.
                              • luckyjoe
                                • 335
                                #30
                                Unless you drive a Ford! When I travel I refuse to rent Fords because they override the AC when Defrost is selected!
                                Tom P.
                                1965 exMoD 109
                                1995 RRC LWB w/EAS
