I have an electric winch for my SIII 88. It was mounted recessed down between the frame horns on a plate that looks like came with it. I have been having a little trouble with my starter and this unit blocked the ability to use my crank handle. Can someone post some picture of mounts for winches that do not obstruct using the crank handle?
winch Mounts
Jim,
thanks, looks like what 3/16" plate welded as an angle to the width of the frame? The crank is very handy for valves, ect that's why i want to make it useable.THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HTComment
Warn M8000 mounted to a standard Warn plat that was $75 from Amazon - fit on top of the frame horns exactly
Jim, any more photo's of the winch mount setup?Comment
Yea Jim I'd like to see some more pic's also. How did you tie it into the bottom of the frame, pics of that would be good also.THING 1 - 1973 88 SIII - SOLD
my solution
I have a Warn 8274 plopped between the frame rails on one of Pangolin's bumpers. I wanted the ability to turn the motor with the crank so I did this;
Cut the crank hole from my old bumper, bent it and re-enforced it, bolted it to the underside of my new bumper.
I also had to lengthen my crank to clear the fairlead. I did this by cutting a section from an old one and splicing it in the middle of my "good" one.
geneComment
pretty snazzy idea! I also believe Ike mentioned that he makes winch bumpers with the retained ability to use the crank, but that there were no pictures on his site at the moment. I wonder if his are of a similar design.Bad gas mileage gets you to some of the greatest places on earth.Comment
I just welded in a 2" receiver in line with the crank. Slightly offset in the bumper but it works fine and gives me an option to mount receiver accessories.Jason
