winch Mounts
  • siii8873
    • 1013
    winch Mounts
    I have an electric winch for my SIII 88. It was mounted recessed down between the frame horns on a plate that looks like came with it. I have been having a little trouble with my starter and this unit blocked the ability to use my crank handle. Can someone post some picture of mounts for winches that do not obstruct using the crank handle?
    THING 1 - 1973 88 SIII - SOLD
    THING 5 - 1958 109 PU
    THING 6 - 1954 86" HT
  • JimCT
    • 518
    home built mount
    I wanted to be able to use the handle on ours, the easiest way to turn the engine when setting the valves. Jim
    1963 Unimog Radio box
    1995 LWB RR
    • siii8873
      • 1013
      Jim,
      thanks, looks like what 3/16" plate welded as an angle to the width of the frame? The crank is very handy for valves, ect that's why i want to make it useable.
      • NickDawson
        • Apr 2009
        • 707
        Warn M8000 mounted to a standard Warn plat that was $75 from Amazon - fit on top of the frame horns exactly
        • JimCT
          • 518
          channel
          It is a piece of wide channel and it is tied into the bottom of the frame too, not just the bolts.
          1995 LWB RR
          • scatterling
            • 183
            Jim, any more photo's of the winch mount setup?
            Neil Hanekom
            '73 LHD 88
            '99 D1
            • JimCT
              • 518
              photos
              I will try and take some this weekend.
              1995 LWB RR
              • siii8873
                • 1013
                Yea Jim I'd like to see some more pic's also. How did you tie it into the bottom of the frame, pics of that would be good also.
                • ignotus
                  • Sep 2009
                  • 237
                  my solution
                  I have a Warn 8274 plopped between the frame rails on one of Pangolin's bumpers. I wanted the ability to turn the motor with the crank so I did this;
                  Cut the crank hole from my old bumper, bent it and re-enforced it, bolted it to the underside of my new bumper.
                  I also had to lengthen my crank to clear the fairlead. I did this by cutting a section from an old one and splicing it in the middle of my "good" one.
                  gene
                  1960 "bitsa" 88--Ignotus
                  1960 109, 200TDI
                  • stomper
                    • Apr 2007
                    • 889
                    pretty snazzy idea! I also believe Ike mentioned that he makes winch bumpers with the retained ability to use the crank, but that there were no pictures on his site at the moment. I wonder if his are of a similar design.
                    • leafsprung
                      • 1008
                      Crank Provision
                      • I Leak Oil
                        • 1796
                        I just welded in a 2" receiver in line with the crank. Slightly offset in the bumper but it works fine and gives me an option to mount receiver accessories.
