Steering box lubricant?
  • fred98050
    • Aug 2010
    • 104
    1960 ,109
    What kind of lubricant should I use in the steering box?
    Thank you
    sigpic
    1964 88 S2A, petrol 2.25L.
    Weber 32/36 dvg
    Lucas distributor
    2.5 Na Conversion:
    http://gallery.me.com/flangenard#100941
    What I like the most about my Rovers? They've got more problems than I do...
  • KevinNY
    • 484
    Officially 90 Weight, but this is great place to put One Shot swivel grease.
    • Monkeyboy
      • 22
      Must admit that the constant drip of an old box led me to fill it up with STP once.
      Worked okay, and when disassembled - after sitting for some time and half full of water - was not a spot of rust in there!
      Don't worry, you're biodegradable.
      • fred98050
        • Aug 2010
        • 104
        Thank you.
        Any downside ?
        sigpic
        Weber 32/36 dvg
        Lucas distributor
        2.5 Na Conversion:
        • rejeep
          • Apr 2010
          • 420
          Old willys jeeps with a similar cam and lever design use a mixture called "knuckle butter"......
          It's really just a mix of gear oil and grease.... Google it..
          I have used it for years and it works great...
          I have also been told synth great oil is the way to go....
          1971 SIIa 88" NAS Dauntles V6
          1974 SIII 109" RHD
          • Andrew IIA
            • Feb 2008
            • 327
            Yes. I switched from 90wt to One Shot swivel grease also
            Andrew
            '63 SIIA 88" SW
            • lrdukdog
              • 321
              others
              Well, I suppose you could use vegemite or marmite some folks say that's the only thing they are useful for . If not then "what he said".
              Jim Wolf
              • fred98050
                • Aug 2010
                • 104
                Guys, thank you for your help.
                frederic
                sigpic
                Weber 32/36 dvg
                Lucas distributor
                2.5 Na Conversion:
                • fred98050
                  • Aug 2010
                  • 104
                  By the way, should the box be full of fluid, 1/2 full? Can't find the specs.
                  Thanks
                  sigpic
                  Weber 32/36 dvg
                  Lucas distributor
                  2.5 Na Conversion:
                  • Terrys
                    • May 2007
                    • 1382
                    Jim Wolf
                    For many years, in addition to running a steel foundry here in CT, I represented a large British steel foundry in the US, located in Burton on Trent. I also spent a good deal of time in Sheffield doing developement work. I had a desk in Burton, although I was only there 10 days or so each quarter. Directly across the road was the main Bass Ale brewery. Sadly, to the south of the Bass plant was the largest Land Rover breakers yard I've come accross. Just up the road from Bass, to the north, was the plant that made Marmite, which used the waste from Bass. No one ever complained about the odor from the foundry because the Marmite odor in the air was worse.
                    • Wander
                      • Jan 2010
                      • 260
                      On my IIa it's until the fluid is to the bottom of the filler hole which I interpret as pretty much full.
                      64 IIa 88
                      94 Discovery
                      06 Toyota 4R (DD)
                      ~Matt
                      "Not all who wander are lost"~Tolkein
                      • LaneRover
                        • 1743
                        If there is another way than this I don't know it!
                        • fred98050
                          • Aug 2010
                          • 104
                          Just opened the filler of the steering box.The level was pretty much right there, at the top of the filler plug...
                          Thanks
                          sigpic
                          Weber 32/36 dvg
                          Lucas distributor
                          2.5 Na Conversion:
                          • disco2hse
                            • Jul 2010
                            • 451
                            Jim Wolf
                            HmmmmmMarmitehmmmmm
                            Alan
                            109 Stage 1 V8 ex-army FFR
                            2005 Disco 2 HSE
