My project is moving slowly pending locating a winter workspace, but I'm preparing for some winter indoor projects just in case. Yesterday, I removed the left fender with intent to access and remove the brake pedals and associated brackets and hydraulic cylinders. The hitch I ran into is that the 6 hydraulic line fittings (2 out of fluid reservoir & 2 in & 2 out of the 2 hydraulic cylinders) are rusted solid. ONe fitting on the reservoir loosened but the line twisted and immediately snapped. Sprayed again with PB Blaster and retired to consider.
I want to review my conclusion to see if it a reasonable course.
That is: it is full speed ahead........ the lines have sat rusting inside and out for 28 years and even if they came off intact I should replace them. Therefore, I propose snipping them and discarding. This approach simplifies things and assumes that new piping is required, even if I could get them off of my car, (or the donor).
Thoughts?
Thanks again.
Lastly,
this rover has been in my family since I was a kid. It's just been reclaimed from a field. Yesterday, in cleaning out the cab, removing the heater and ductwork I found my next project....... a tr3 that has also been in the family for years.
See photo
Thoughts?
Thanks again.
Lastly,
See photo
