Cutter, that battery is probably most of the problem.
Howzit running (once it starts)?
For what it's worth, I use radiator hose heaters in my heaps (and they are all diesel, and need help) as they are just as effective as the heaters you can fit in a Rover freeze plug and much less hassle to deal with. I have had to remove more leaking block mounted heaters, some that even short out the "shore power" over the years. Most were probably pretty old. I have had to remove hose mounted heaters for the same reason. It's pretty easy to carry a splice for a hose but it's a pain in the arse to repair the freeze plug.
The only thought I had in regard to the hose heaters is possible hose restriction leading to temp issues in summer but have yet to notice any issues with that
