I recently replaced a set of Geolander A/T S on my DD with a set of Cooper Discoverer AT3s. I liked the Geolanders for the first winter, and they were pretty decent in the Mud. (They were on a Lexus GX470, but I do use it off road some). The second winter, when the tread wore down, they were horrible. I switched them out for the Coopers before this past winter, but will be swapping the Geolanders back on for the summer so I can get the last bit of tread use out of them. The wear nicely, are quiet on road, but are just disappointing as they wear down.
Another tire size question (sorry)
I ended up ordering the 225/75/16 Geolanders A/T-S. We will see how they wear and I will update. Most of my driving is highway (60 miles round trip for work) although I will also use for some light off road. The Series is not my primary vehicle, so it won't be used heavily in snow; major snows in Richmond, VA, typically involve accumulations of 1" or less. Pretty brutal I know...~ Corey
1974 Series III RHD SWB
2003 FreelanderComment
I just received five Kuhmo 215 85 16's from tire rack. I'll put them on this weekend. They are about the same width and diameter as the 7,50's now on the truck.Tom Smith
'60 88" driver
'53 80" project
'60 Morgan drver
'60 Morgan project
33 Farmall F12Comment
yorker....thanks for the post....nice read with pics!
pgeorgeson..I just scored a set of four 7.50x16 M/S for my 109 today. If you need dimensions, just let me know. I also run 215/85x16 on my dually. Again, let me know if you need dimensions.64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucksComment
1963 Unimog Radio box
1995 LWB RRComment
Without an OD:
215-85-16s are usually 30.5" tall and = 3870 rpm at 65 mph
235-85-16s are usually ~32" tall and = 3700 rpm at 65 mph
215 85 16s are a pretty nice size on 88s. Stock 88 tires were originally 28.5-29" tall somewhat similar to a 205-80-16 today, that would put you ~4070 rpm at 65 which could definitely benefit from an OD. The only advantage I can see for the smaller diameter tires is somewhat easier acceleration and less stress on the drivetrain, oh and they are sometimes available in a load range better suited to an 88's capacities. That could translate into a better ride.Comment
65mph without an OD?
Without an OD:
215 85 16s are a pretty nice size on 88s. Stock 88 tires were originally 28.5-29" tall somewhat similar to a 205-80-16 today, that would put you ~4070 rpm at 65 which could definitely benefit from an OD. The only advantage I can see for the smaller diameter tires is somewhat easier acceleration and less stress on the drivetrain, oh and they are sometimes available in a load range better suited to an 88's capacities. That could translate into a better ride.THING 1 - 1973 88 SIII - SOLD
THING 5 - 1958 109 PU
THING 6 - 1954 86" HTComment
