Front License Plate Mounting Options
  • east high
    • Jan 2008
    • 337
    Up in Oregon it's required that your vehicle has a front license plate. Since my sIIa doesn't have provisions for hanging a plate on the front, I've been leaning it up in the front window thinking this would be sufficient. According to the ticket ladies, it isn't.
    So here's my dumb question for the new year. Is there a kit or something to mount a plate to the wing, or should I just git-r-dun with a few sheet metal screws? I'm only asking because I know the rear plate has a little more going on back there than a couple nuts and bolts.
    '67 sIIa 88
    I just used the front license plate mounting plate off a Discovery I. Junk yards are full of those Discovery I's.
    • 73series88
      • Oct 2009
      • 587
      i see alot of people with plates and inboard lights mount them on the front of the wing below the lights.
      cheers
      aaron
      67 series 2a 88 RHD sold
      88 RRC sold
      60 mga coupe
      • 73series88
        • Oct 2009
        • 587
        sorry i didnt read deep enough into the question.
        that was your idea already
        aaron
        88 RRC sold
        60 mga coupe
        • jac04
          • 1884
          Several of my Rovers have had a plate mount at the center of the front bumper, and they have all looked the same. This leads me to believe that the mount is a LR part. Maybe someone at RN had a part number.
          • siii8873
            • 1013
            two of my trucks also had the plate jac04 noted. on my other one I drllid two holes in front bumper so bottom of plate was even with bottom of bumper. pictures of both below.
            THING 1 - 1973 88 SIII - SOLD
            THING 5 - 1958 109 PU
            THING 6 - 1954 86" HT
            • Les Parker
              • May 2006
              • 2020
              The NAS sized plate Part Number is :-
              90577144 Plate, though this is no longer available from Landrover.
              It's an easily made replacement, a right angle plate the same dims as a regular license plate. The mounting holes should be either already in the front bumper or marks in the bumper for mounting holes to be drilled. No big deal to make one for yourself, maybe out of some galv. sheet steel.
              Les Parker
              • east high
                • Jan 2008
                • 337
                Thanks for the help guys. It's good to know that LR did have a factory option. I'll probably end up mounting on the wing still as there would be less chance of it getting in the way.
                '67 sIIa 88
                • masonater
                  • Nov 2007
                  • 329
                  I always zip tied the plate to the grill, that was until MA decided zip ties were not safe. Now they require bolts. On my RRC i had it mounted under the bumper and bent it way backwards so it was hardly noticeable and still passed inspection.
                  1970 Series IIA 109 EX-MOD
                  1971 Series IIA 109 EX-MOD
                  1982 Mercedes 300TD
                  1989 RRC
                  1993 D110
                  1994 RRC LWB
                  1995 RRC LWB
                  1995 RRC LWB
                  1995 Disco
                  1996 GMC 2500 Suburban
                  1996 Disco
                  1997 Disco
                  2001 RR P38
                  2005 LR3 HSE
                  2006 RR HSE
                  • 73series88
                    • Oct 2009
                    • 587
                    if you go the the parts wanted and post that your looking for an
                    original bumper mounted licence place mount,
                    im sure someone has a few sitting in there garage.
                    aaron
                    88 RRC sold
                    60 mga coupe
                    • leafsprung
                      • 1008
                      You might double check, I think if it didnt come with a provision for a front plate, its not required . . . I run a few series trucks with just a rear plate and have not had issues.
                      • east high
                        • Jan 2008
                        • 337
                        That's what I'm sayin... it's just these overzealous neighborhood ticket ladies bustin my chops. I looked up the actual law and all it says is that a plate needs to be displaid clearly, which I'll let you decide.
                        '67 sIIa 88
                        • 73series88
                          • Oct 2009
                          • 587
                          man thats a nice rover!
                          oh i see the bumper
                          no place to put it
                          looks like you would have tot into the front of the wing
                          aaron
                          88 RRC sold
                          60 mga coupe
                          • TeriAnn
                            • 1087
                            The long NLA factory plate holder is just a piece of sheet metal with a right angle bend near the bottom that is drilled for mounting to the bumper top.
                            If you don't want to go through the effort of duplication the factory solution, the plate looks OK mounted directly to the wing front panel:
                            At least I think it does
                            • Terrys
                              • May 2007
                              • 1382
                              I agree with TA, especially on her truck. However, if you want to use a US plate holder, as described by many here, I have one (presently under 3' of snow I think) you can have. You could mount it atop your bumper but to the side, in front of the wing, if you didn't want to drill into the wing panel.
