Tail light problem
  • derekchace
    • May 2008
    • 463
    Tail light problem
    Its would seem today when I went out today my tail lights have stopped working. Its a 1982 109 Series III MOD I weird part is they still come on when I press the brake, the blinkers work but when I flip the light switch on only the head lights come on no tail lights or plate light. Any ideas on where to start?
    GMR Imports
    802-655-4874
    802-324-3370
    gmr4x4.com
  • stomper
    • Apr 2007
    • 889
    IIA or III? if a IIa, check the connections to the ignition switch first. May be a loose spade connector, or a disconnected wire there.
    • derekchace
      • May 2008
      • 463
      Its a Series III ex MOD 12v.
      GMR Imports
      802-655-4874
      802-324-3370
      gmr4x4.com
      • Terrys
        • May 2007
        • 1382
        Do you have a plain, civilian headlight switch, or the 6 position MOD headlight switch? One of the positions on MOD trucks is headlights on, NO tail lights except convoy light, under the truck, shining on rear diff.
        • derekchace
          • May 2008
          • 463
          its a regular civilian 3 way switch. No convoy lights.
          GMR Imports
          802-655-4874
          802-324-3370
          gmr4x4.com
          • jac04
            • 1884
            ^^Was it always that way or did someone remove the 6-way? If the civvy switch was a retrofit, I would look at the wiring job.
            • cousindave
              • Jan 2007
              • 192
              Same thing happened to me recently. Mine happened to be the ground connections at the rear tub. Also check all the bullet connections from the light switch all the way back to the tail lights. Mine were so full of gunk that I eventually cut and soldered the connections. Couldn't believe how bright the lights are now! One more thing, before you go crazy doing all this stuff, change your light bulbs and clean the tail light assemblies and apply some dielectic grease on the bulbs. Good luck!
