Its would seem today when I went out today my tail lights have stopped working. Its a 1982 109 Series III MOD I weird part is they still come on when I press the brake, the blinkers work but when I flip the light switch on only the head lights come on no tail lights or plate light. Any ideas on where to start?
Tail light problem
Tail light problem
Tags: None -
its a regular civilian 3 way switch. No convoy lights.Comment
Same thing happened to me recently. Mine happened to be the ground connections at the rear tub. Also check all the bullet connections from the light switch all the way back to the tail lights. Mine were so full of gunk that I eventually cut and soldered the connections. Couldn't believe how bright the lights are now! One more thing, before you go crazy doing all this stuff, change your light bulbs and clean the tail light assemblies and apply some dielectic grease on the bulbs. Good luck!Comment
