how big an alternator can you install? and what horn sounds the best?
  • glbft1
    • 149
    Hello all,
    Was wondering how big an alternator can you install on a series 2a 109 without frying anything?( running winch and lights)
    Also wanted to get a new horn wanted the European high tone horn just want a cool sound!
    Greg
    If the truck has an ammeter get rid of it. Wire the alt. direct to the battery. Wire the accessories correctly and you won't have any problems running as high an amp alt. as you wish. Whether or not the stock belt setup will drive a super high amp alt. is a different story though.
    • albersj51
      • May 2010
      • 687
      I'm running a 78 amp on my 2a with no problems. As stated, disable the ammeter to avoid pegging it and then angering the Lucas Smoke Monster.
      • glbft1
        • 149
        what is a ammeter? sorry still on the quest for all things rover
        Regards
        Greg
        • gudjeon
          • 613
          An ammeter takes a measure of current of the charging system. Personally, I like installing a voltmeter instead. For onr thing, they are cheaper, and measure the state of voltage for your entire system, not just what the alternator is doing. So with this, you can see if it is actually keeping up to the electrical load of the devices. I run a largish Delco alternator and have no problems with it charging on running a single belt.
          A larger alternator will not fry anything if the the rest of the system is up for it. A small output dynamo or small output alternator is just as capable of "frying" the electrical if anything goes wrong. A high output alternator can keep up with the draw of high demand (high amperage) devices like a winch and aux. lights. The idea is that you can have your stuff turned on like lights, heater, wipers, etc and still have enough capacity left over to charge the battery while driving.
          Think of amperage of "heat" or power and Voltage as the pressure to push it through the wires.
          • stomper
            • 889
            This link was posted on another forum, about the differenced between an ammeter and a volt meter. I will give credit to the original poster, who is on this board too, Safeoneair.
            • Terrys
              • May 2007
              • 1382
              Greg, an ammeter is a current measurement device. In automotive applications, they are used to measure the current drain from the battery, and Zero, indicates current drain from the battery is matched by current output from the generator. If it's reading positive, you are giving back to the battery more than you are draining from it. When it's reading negative, you're drawing more from the battery than the generator is puting back into the system. In older, generator applications, the zero center ammeter had a range greater than the generator, and was wired into the system between the battery, and all loads (Heavy Brown wire) Older Land Rovers had an ammeter range of about 30 amps, but you can replace it with a higher capacity ammeter, like -60 - 0 +60. They generally don't go higher than 80 amps without having to go to an external shunt. The general thought process is that a voltmeter (really just an ammeter) that reads up to 16 volts or so, gives more information. It doesn't really give you more information, it is just a better indicator of battery condition. An ammeter still tells you more easily to what extent you are loading down the system.
              Technically, all voltmeters are ammeters, whose scale is in volts. They have a known, fixed internal meter resistance (like a small load), and because they are parallel to the loads, act like a current divider ( Ohms law E=I/R)
              • glbft1
                • 149
                I looked on my dash no ammeter at all, do hve a red light that comes on until i rev up the engine a little and it goes out then stays out... is it possible it never had one?
                Greg
                  VERY possible. Probable, in fact.
                  He has a screen name very similar to mine!
                    Oh...As for which horn sounds the best, it's pretty subjective, but I like this one.
                    • LR Max
                      • Feb 2010
                      • 315
                      I have a 70...or 90??? amp alternator off of a Jag. Works well with my extra lights, winch, etc.
                      I have the hella horns. It sounds like one of the jeeps off of MASH.
                      • Nium
                        • Aug 2009
                        • 400
                        Air Horn
                        I'm kinda partial to air horns. Like that you would see on a mac truck except a little smaller so it'll fit under the hood. Definitely not original to a Landy but one blast of that thing and anyone on a cell phone with the music blaring will definitely hear you coming. If your close enough you may even scare them off the road.
                        A down side to an ammeter that wasn't mentioned is that they have to be wired in series with the load being monitored. Which means an unfused line from the alternator through the firewall to the ammeter on the dash and back out to the solenoid. Kinda dangerous (IMHO) because of all the electricity flowing through it. If a fuse was put in line with the ammeter then the alternator would fry itself if the fuse blew. A self resetting circuit breaker could be used instead of a fuse but expensive and hard to find. Voltmeter definitely safer and less likely to cause a fire if the wire insulation gets knackered and grounds out.
                        Size of alternator...as big as you can fit in thar, but do you really need some monstrosity? What are your plans?
                        Walker
                        1968 Series IIA-"Ronnie"
                        88" SW, 2.25L Petrol, LHD
                          • 400
                          I have a 140 amp standard size Delco on a Pangolin mount on my 109. The wife's 3.9 V8 109 has a similar 140 amp Delco for normal loads and a second big case 140 amp Delco for the winch battery and other accessories.
                          I run a single belt to each alternator, but it is recommended that anything over 100 amps should be driven by twin belts.
                          I have the standard barely audible horn on my 109. The wife's 109 has triple Fiaam (sp?) air horns, with the SIIA horn button closing the ground on a relay that powers the air compressor.
                          '02 Disco II SD
                          '80 SIII 109
                          '75 SIII 88 V8
                          '68 SIIA 109 V8
                          • glbft1
                            • 149
                            I wanted to just run a winch extra lights one set and a cb the alt has double belts now will clean up and see what size, the PO had the generator switched out and a alt installed with a new brace pieces( aftermarket alt holder)
                            It has a optima yellow top battery the goal was maybe increase the alt to work the heaver draw..
                            Thanks everyone !!
                            Greg
                            • LR Max
                              • Feb 2010
                              • 315
                              Yeah, do the AC Delco swap and when winching, keep your RPM's around 2k.
                              You won't have any problems.
                              When I do my once-a-month winch, I leave the truck off and winch in the entire 100~ish foot of rope. There is plenty of juice left in the battery (granted, it is a light load on the winch but still it is running for a while).
