If you have a 3 wire system you can run as big an alternator as you can imagine. It will only put out the amps on demand so as long as it is rated to meet your max load (Sit down and calculate this rather than guessing at teh biggest unit you can fit) you'll be just fine. Note that you usually have to run the engine at a minimum rpm for the alternator to be producing any output so, unless you are lucky, or have played with the pulleys to get the correct rpm, it won't be doing much at idle. A hand throttle helps here.
Of more importance to your original question is the gauge and condition of the wire in your charging system. Its been a long time since I looked at an original Rover wiring loom but IIRC the charge wire is 12AWG which should be good for about 25.5A. Someone can correct me on that. I would want a minimum of 10AWG (Preferably 8AWG) and probably double it up to the main load point if I was running a winch. I'd also install a Maxi fuse in the line to protect the truck if the alt control goes wrong.
