engine upgrades
  • Lord Icon
    • Jul 2008
    • 176
    engine upgrades
    Any body change out the carb (z,sol, web) and upgrade to a throttle body injection system? I am commissioning a system and if i don't have to re invent the wheel it will be cheaper....
    This is a stepping stone for me till I get the time and cash and energy to do the 200di swap out.
    Whence came you my brother ? From the East....
  • mongoswede
    • May 2010
    • 757
    Have not heard of anyone doing it but there is no reason it cannot be done. Why bother with an antiquated TBI system when you could do a little manifold work and go to a modern multipoint efi. Systems like Mega-squirt and others are fairly easy to work with and apply to any engine.
    to limit expenses and the need for making a wiring harness you could look for Saab 900's in the junkyard from year 1986 through 1993 and pull out the fuel injection wiring harness. These harnesses come out of the car reasonably easily and only require a few outside connections like power, ground, etc. They have 4 fuel injector connectors and other sensor connectors that could be used and programmed into a megasquirt computer. There is a guy on the Saab forum that makes an adaptor which allows you to plug the megasquirt computer into the Saab harness. Would probably lay into a rover engine bay nicely and you could mount the computer inside out of the elements (or as away from the elements as you can get in a rover).
      I believe LRMax commissioned a FI system for his, or atleast attempted to. Might pick his brain....
      • Eric W S
        • 609
        There's a throttle body conversion on Discoweb or GnR. Search.
        Why waste the money if your are going to swap to a 200di? That makes no sense.
        • mongoswede
          • May 2010
          • 757
          Agreed...didn't even register the 200TDI swap until now.
          • Lord Icon
            • Jul 2008
            • 176
            er, tbi upgrade 300-500$ no engine removal......
            200di $2900 plus shipping and many hours under and in my rover engine bay.
            I figure I did this with my Unimog and patented it and made a few quid.
            the 200di would just cost me money as someone else has done all the brain work...
            Besides, the MRS. wants to know why I just can't improve this engine that works " fine" the argument for better fuel economy just is wasted as the rover is not used that often..
            • yorker
              • 1635
              Land Rover UK Forums
              • msggunny
                • 621
                What about this:
                With this manifold:
                and a bit of machine work for an adaptor?
                04 DII
                08 D3 (LR3)
                • solihull109
                  • May 2007
                  • 191
                  You're thought process makes zero sense here. If you really think for a moment that a 70 something horsepower engine is going to be more efficient moving the weight of a series truck you're kidding yourself. If you are looking at gaining more *mpg's* than you need to consider the alternative, which would be a diesel, which also does not mean a Rover diesel either. These trucks are tractors folks, not a Prius.
                  If you want to improve the 2.25 that's in there now, keep it well tuned and maintained.
                  knowledge without experience is just information.... Mark Twain
                  www.downeastcoachworks.com
                  • mongoswede
                    • May 2010
                    • 757
                    true...but there are certain things that a modern EFI system give you beyond the possibility for improved efficiency. The modern DIY systems are infinitely tuneable for your application and you can plug a lap top in and see whats going on. You can optimize the fuel delivery for the engine and the driving conditions. While its doubtful that you will see a fantastic increase in mpg you will likely find the engine runs better in a wider variety of conditions. However, the other side of this project is that it would be a good idea to design and build a different intake manifold. The stock rover manifolds are short and fat which tends to optimize top end hp while long skinny runners tend to enhance low end torque. So an efi system and a properly designed intake manifold mated with a properly flowing exhaust manifold and exhaust could be a big difference in the performance. On top of that you could reduce the flywheel weight and improve reving speed.
                    In the end you will be limited because the cylinder head design is just poor to begin with.
                    • Eric W S
                      • 609
                      Get a rebuilt Solex and like others said keep the engine in tune and you'll get the most bang for your buck performance wise.
                      Why even bother with the 200di swap? Gutless enough with a turbo and without not much better than a well kept 2.25 petrol.
                      • Terrys
                        • May 2007
                        • 1382
                        Have you ever driven a truck with a 200Tdi? Hardly what I would call gutless.
                        • east high
                          • Jan 2008
                          • 337
                          Originally posted by msggunny
                          What about this:
                          With this manifold:
                          Gah! Now I have yet another thing to daydream about. Thanks, msgunny :P
                          BTW, what's different/better about that manifold compared to stock?
                          '67 sIIa 88
                          • gudjeon
                            • 613
                            That Holley TBI is one sweet piece of kit. Hmmmmm. If/when I get a tax return...
                            • albersj51
                              • May 2010
                              • 687
                              Wow! $1800!?! Im all for turning the rover into EFI, but at that price ill take my carb and like it.
