engine upgrades
  • xsbowes
    • 258
    #16
    Originally posted by Lord Icon
    er, tbi upgrade 300-500$ no engine removal......
    little higher with the holley:
    $1800 for the 550
    $190 for the manifold
    Stacy
    Motta S.A. Italy
    • gudjeon
      • 613
      #17
      I can always, and have done numerous times, fixed my carb.
      • mongoswede
        • May 2010
        • 757
        #18
        $1800 for the 550
        kit:
        EGR No
        Injection Style Throttle body
        Metering Style Speed density
        Intake Manifold Included No
        Fuel Rails Included No
        Throttle Body Included Yes
        Throttle Body Mounting Flange OEM 2-barrel
        Venturi Quantity 2
        Airflow Rate (cfm) 670 cfm
        Throttle Body Material Cast aluminum
        Throttle Body Finish Natural
        Injectors Included Yes
        Calibration Module Included Yes
        ECM Included Yes
        Wiring Harness Included Yes
        Oxygen Sensor Included Yes
        Fuel Pump Included Yes
        depending on the kit you may or not need the pieces below.
        Fuel Pressure Regulator Included No
        Distributor Included No
        MAP Sensor Included No
        IAT Sensor Included No
        TPS Sensor Included No
        IAC Motor Included No
        Quantity Sold as a kit.
        Notes Designed for engines up to 275 horsepower.
        • east high
          • Jan 2008
          • 337
          #19
          Originally posted by mongoswede
          I looked the kit over and it looks like you will still need a fuel pump, and some other sensors. I didn't see whether it was a MAP system or based on airflow but those additional sensors will add some more cost to the kit. Not sure what sort of fuel pressure it requires but its likely it will need a high pressure fuel pump...so some more cost there. Things to keep in mind.
          According to Holley, it comes with everything you need for installation except for a manifold and return fuel line.
          '67 sIIa 88
            #20
            And after all this it's going to get 5hp more and 2 mpg better or what? The 2.25 is what it is....you can't polish a terd.
            • msggunny
              • 621
              #21
              $1800 for the 550
              Forgot $$$(?) for the adaptor to make it fit to the manifold.
              04 DII
              08 D3 (LR3)
              • LR Max
                • Feb 2010
                • 315
                #22
                $1800? HA. You can build your own for a fraction of that...because I did.
                For mods, I've got a rover head shaved to Kingdom Come, .030 over pistons, ACR camshaft and a Rochester carb.
                Once the shop is done removing the JAKE brake valve adjustment, I'll let you know.
                • Eric W S
                  • 609
                  #23
                  Originally posted by Terrys
                  Have you ever driven a truck with a 200Tdi? Hardly what I would call gutless.
                  I have. Not too impressed with the motor given it's cost to performance ratio. I want to drive one of Timm Cooper's creations. That's the way to go for motor replacement IMO. Quick jacking around with crap from LR and fix the problems...
                  • solihull109
                    • May 2007
                    • 191
                    #24
                    I would like to thank some of you guys. It's been long hours for several months. I needed a good chuckle.
                    I'm actually amazed that some of you would consider spending the money on a foolish mod like this when most of you are too cheap to just keep the truck tuned up and in good running order in the first place.
                    Oh, EWS, you're right on the money. If you're going to do it, might as well go big.
                    knowledge without experience is just information.... Mark Twain
                    www.downeastcoachworks.com
                    • xsbowes
                      • 258
                      #25
                      According to Mythbusters, you can!
                      Stacy
                      Motta S.A. Italy
                        #26
                        http://www.youtube.com/watch?v=yiJ9fy1qSFI
                        Ok I guess the terd polishing experts have it all over me on that one...it's still just a terd.....
                        • mongoswede
                          • May 2010
                          • 757
                          #27
                          I have my own engine selected for the next rover. but I didn't want to muddle the already turbulent thread.
                          • Eric W S
                            • 609
                            #28
                            Hopefully your mantra is WWTCD? What would Timm Cooper Do?
                            EwS
                              #29
                              It's probably a Saab 4 banger.
                              • Eric W S
                                • 609
                                #30
                                That there is the truth. It's easier to whine and complain than to just fix the problems.
                                The 200tdi is just over paying for ease of installation.
