Alpine Windows
  • Apis Mellifera
    • 386
    Alpine Windows
    I now have the windows! Could someone with an 88 with AWs measure the distance from the end of the window to the back of the top and from the rain gutter up to the bottom of the window?
    Many Thanks
  • Terrys
    • May 2007
    • 1382
    Aaron, 75siii88 just did this install. Hello Aaron?
    • 73series88
      • Oct 2009
      • 587
      morning
      let me get some coffee in my blood and scratch up some pictures.
      i ended up just eyeballing them but they came out pretty good
      aaron
      67 series 2a 88 RHD sold
      88 RRC sold
      60 mga coupe
      • scott_b
        • Jan 2011
        • 15
        Nice job!
        Did you use the glass to trace an outline? How much larger than the outline did you make the hole? What did you use to cut the top?
        Thanks!
        scott_b
        1975 SIII 88" RHD
        • Triumphdaytona2007
          • Aug 2010
          • 87
          wow! awesome job looks great
          1964 Series IIa 109" Pick-Up RHD
          1965 Series IIa 88" Wagon LHD
          1968 Series IIa 109" Station Wagon LHD
          • yorker
            • 1635
            Land Rover UK Forums
            • 73series88
              • Oct 2009
              • 587
              ok
              5.25 inches from the back of the top and 1 inch from the drip rail
              i traced the glass in that position then outlined it by .25 inches.
              used a drill to start the hole then used a jigsaw with a plywood blade for the smoothest cut. filed down the edges so nothing would get caught.
              cut the larger seal so the brake in the seam was at 6 oclock. make sure you leave a little extra. you will need it. i put some wd 40 in the seal to make the glass go in a little eaiser. then the filler seal in so the joint was at 12 oclock. you will need the filler seal tool to get that in. i borrowed one. i think there are a few floating around the forum.
              i dont run a headliner so im not sure about that part
              i definately like the way they look though.
              good luck
              aaron
              88 RRC sold
              60 mga coupe
