Read this in a 4X4 mag and tried it myself. Take kidies sidewalk chalk and mark your tires from edge to edge in 2 different places, 90deg and 45 or similar. Drive in a straight line, 50-100 ft, with your tires at normal operating temprature and then check the tires. if the chalk is worn only in the middle then you have too much air. Worn on the sides only, not enough. The chalk should be worn evenly across, air up or down until you get there.
Hope it helps and i didnt confuse anyone.
04 DII
08 D3 (LR3)
hey momo, I'm just trying to be helpful. not sure what you think you are gaining by running two times the manufacturer's pressure. But from looking @ your photograph it appears the outer tread blocks are twice as deep as the inner rows.
best,
Dave
Originally posted by Momo
That was me Dave- and I gotta call BS on that. My tires are ten years old with 30k miles.
I have an issue especially arounr 35-40 mph with the steering wheel shuddering back and forth. A little unerving. Could this be from incorrect tire pressure? Seems better under acceleration and worse when not under throttle? Any thoughts?
No worries Dave, as they say "your mileage may vary". Actually the lighting in the photo may be misleading- the tread is a bit more worn on the outside due to normal cornering etc. but otherwise they are evenly worn.
Mfr. pressure is max 80 psi cold. Only reason I ran them @ 75 was all the freeway driving I used to do, it cut down on rolling resistance. Oh, and parking lot maneuvers! Definitely makes a difference but like I say you pay for it in ride quality- if a Series truck can even have such a thing.
Gunny, I like the chalk trick. I'll have to wrestle my kid for it though.
'60 SII Station Wagon
'64 SIIA 109 Regular
'68 SIIA 88 Station Wagon
yes, my mileage will vary. you may get more MPG but god help you if you hit any kind of surface that offers less than optimal traction. Please, do not advocate this dangerous practice to others. Momo, look on the side of the tire. There you will see where the manufacturer has spelled out for you the maximum pressure for the tire along with a figure in kilograms and/or lbs. If the vehicle is not putting that much weight on THAT tire, then the tire is overinflated. You can protest all you want but it is simply not correct. Yes it is a "free country" but you are endangering yourself and your passengers as well as the occupants of other vehicles. Sorry mate.
sounds like I'm underinflated at 30 psi. Here's what I'm running. I can't make out the size though lol. (the truck is an hour away so I can't go look at it). By the way this is the leakiest hub I have of all 4...
if it is the kind of shuddering where the wheel is about to be wrenched from your hands, try getting the wheels balanced. additionally you may need to rebuild or replace the steering relay through the frame and/or adjust or replace the steering kingpins, busihngs, and bearings in the swivel housing.
good luck, that is not a fun sensation.
bostonian you are probably fine, I like em a bit higher though one or two do tend to leak, then hold @ around 20ish. I guess I should run tubes. now that i've scolded momo for endangering others I guess I should follow the same practice...
that wheel looks like most I've seen. that kind of leakage is quite common. you may want to check the axle breather though b4 it gets too much worse.
I have to agree with DaveB here. 75psi is waaaaay too much for normal driving. If you try stopping on a slick surface you are going to slide a whole lot sooner at 75psi than at 35psi. The 80psi marking on the tire is a maximum inflation pressure NOT a recommended tire pressure. In other words, if you are going to be hauling a load at or near the tires maximum weight carrying rate, then (and only then) will you need the tire inflated to (or close to) the maximum inflation rating.
It's not rocket science. And just because your tires don't seem to be wearing overly in the center, doesn't mean that you have them at the right pressure. All it means is that the tire may have a stiffer carcass than another tire, which would show wear in the center at the same psi.
You are sacrificing ride quality (such as it is in a Land Rover) and safety (yours and others) at the expense of tire life. Not a worthwhile trade.
Read my original post again, guys. You are taking this way too seriously.
"I've actually run mine as high as 75 psi. Steers easier at low speeds and feels better on the freeway. Downside is a tooth-rattling ride. Been running 45 psi for awhile now. Best of all worlds."
I never advocated any given pressure. I just thought I was answering an informal poll! I never said 75 was not high, and I never said it was a recommended pressure.
Dave's bent because he didn't like my response to his assertion about my tires wearing prematurely. Not tires in general, but my tires. Over that period I ran at high pressure, I watched for increased wear, and it didn't happen.
Maybe I should have been more conciliatory in my approach, but I was using the expression "calling BS" in a tongue in cheek way which obviously went over like a lead balloon. Dave has recieved a private apology for that misstep and I will say it here too, Dave, that I'm sorry I irked you.
But...in fairness to logic, for you to claim that running high pressure amounts to endangering others? In general, that is just ludicrous and here's why:
Over the year period in 2002 when I ran high pressure, I clocked about 8k commuter miles, and on and off for about 1100-1800 fwy miles for long distance trips. Many of those miles were with a cargo load. Always in good weather. Most of those miles were at between 45 and 60 mph and wouldn't be considered pushing the performance envelope by any stretch. We are talking about a Land Rover after all- slow lane, the whole world passing you at 80 mph, et cetera.
Would I run that pressure in the rain, snow, on loose surfaces, or other poor conditions? Of course not. I have the benefit of about 330 days of sunshine per year and two vehicles. JP's point about slick roads is well taken...but a rarity in my neck of the woods. On crappy days the 109 stayed home.
Furthermore, in numerous industry and govt. tests, radial tires have been hydraulically pressurized up to 300 psi prior to failure. Most tire failures were at the bead and in fact many failures during testing were rim structural failures, not tire failures. Radial tires are one of the most technologically advanced items in the automotive industry and their tolerances are well established. If anything underinflation is by far the greatest danger.
Finally, today I called a Firestone retailer to get their take and as expected he agreed that 75 is too high for routine use in all conditions, but he actually laughed when he heard your safety argument and felt it was overstated. His main concern was ride quality and the possibility of premature wear.
Group hug everyone...
Actually everything depends upon the load on the tire as to what the "correct" psi is. 75psi would be probably be ok if all you do is haul bricks around in your loadbed. However, since most people don't do this, 75 is considered high. Also, the psi would not be the same for front and rear tires even if hauling bricks. The rear tires are going to take a disproportionate amount of the weight and therefore will need to be higher than the fronts.
If you had said something like, "I run 35psi in the front, and 45psi in the back due to the amount of hauling that I do," nobody would have said a thing.
Are you endangering others, well we may have been a little judgmental here. However, no one knows you as a driver and most drivers are going to be considerably less safe when they are not prepared for the handling affects caused by overinflated tires (or any other condition they are not used to). You said that you never drive in wet weather, so therefore we can surmise that you don't know how your tires are going to respond in wet conditions at 75psi. If you get caught in a downpour, (which happened to me 3 weeks ago) you are now endangering others, because you don't know how the handling of your vehicle will be affected. Is it a long shot? Maybe, but maybe not.
you are right. we are. apology accepted. I know you live in sunny CA where rain and ice never happen, and was going to mention that. I just want to make sure that the people reading this list who may not know any better understand that it is *not* a good idea to run twice the vehicle manufacturer's suggested tire pressure.
to encapsulate the point, nobody is saying that your truck is going to randomly fly off the road *right now* because of the tire pressure. but at 75 psi your contact patch is reduced and no amount of protest on your part or anyone else's will change the fact that traction is then reduced as well, regardless of the surface.
rgrds
dave
