Smith Heater
  • Partsman
    • May 2011
    • 329
    Smith Heater
    Ok, so I'm new here, and the first 2 threads I actually start make me look very needy. Does anyone in the New England area have an extra round Smith Heater? On mine, the core is shot and leaking. It's all that's holding me up from registering my 109. PM or email Harvey at mallard1990@verizon.net
    Series 2 Club Forum
    Andy The Landy Shop
  • masonater
    • Nov 2007
    • 329
    I'm not sure but a guy here at the airport was scoping out my 109 a while back and saw the heater core on the table. He said it is exactly like the ones in the Triumphs he rebuilds. Never looked into it because mine was good but could be worth an investigation.
    1970 Series IIA 109 EX-MOD
    1971 Series IIA 109 EX-MOD
    1982 Mercedes 300TD
    1989 RRC
    1993 D110
    1994 RRC LWB
    1995 RRC LWB
    1995 RRC LWB
    1995 Disco
    1996 GMC 2500 Suburban
    1996 Disco
    1997 Disco
    2001 RR P38
    2005 LR3 HSE
    2006 RR HSE
    • Partsman
      • May 2011
      • 329
      I've checked those, and yes they are like Triumphs and also Jag heaters are like these, problem is the replacement cores are so damn expensive.
      Series 2 Club Forum
      Andy The Landy Shop
      • cedryck
        • Sep 2010
        • 836
        response to smiths heater dilema
        I had a smiths heater in my 2a. Leaked, smelled, and leaked some more. Replaced it with a Jeep MK heater, almost the same size but square, for 65$ found on colemans.com. Heater works better than the small shin burning smiths pancake one. Throws plenty of heat.
        • Partsman
          • May 2011
          • 329
          Thanks cedryck, this is the best lead I've had since the thing started leaking. You wouldn't happen to have the part # would you?
          Series 2 Club Forum
          Andy The Landy Shop
          • leafsprung
            • 1008
            thats a hupp, have a couple if you want to go that route
            • Partsman
              • May 2011
              • 329
              Got a pic of one? I'm still having trouble finding it on the website that cedryck posted.
              Series 2 Club Forum
              Andy The Landy Shop
              • albersj51
                • May 2010
                • 687
                Look up maradyne 5000. I believe its the new version of the hupp.
                • Partsman
                  • May 2011
                  • 329
                  OK, now this thing is pretty cool, it's actually little smaller than the round Smith, and just about as deep. Does it throw more heat than the shin burner? And can I hook my de-misters into it?
                  Series 2 Club Forum
                  Andy The Landy Shop
                  • albersj51
                    • May 2010
                    • 687
                    It says it is capable of defrosting. As for heat, I think it puts out 12,500BTUs, which is more than the shin burner. How much more, I dont remember.
                    • albersj51
                      • May 2010
                      • 687
                      Here are the specs
                      • Partsman
                        • May 2011
                        • 329
                        Well now that's pretty impressive, and over-all cheaper than buying a replacement core for the round Smith, and more readily available. Thanks albers
                        Series 2 Club Forum
                        Andy The Landy Shop
                        • albersj51
                          • May 2010
                          • 687
                          Glad to help! Look at the 8000 series. Its 2" taller, deeper and wider, but its 25000 BTUs. Do you know the shin burners dimensions? Would the below fit?
                          • Partsman
                            • May 2011
                            • 329
                            http://www.maradynemobile.com/803012Heater.html
                            The Shin-burner is 8wx10Hx6D
                            The 8" part is the circular part, the 10" is to the top of the defroster plenum, it's mostly the depth that I have to be careful about, as this is mounted just above the pedals, so if it gets too deep, it'll interfere with the operation of the Rover.
                            Series 2 Club Forum
                            Andy The Landy Shop
                            • albersj51
                              • May 2010
                              • 687
                              I'm going to replace my shin burner and am looking at the maradyne as well (odd thing to think about as its 92 outside at the moment). Ive thought about moving it to the passenger side for 3 reasons:
                              1. No more intererence with the pedals
                              2. It looks like the defrost output is on the left side, so routing the duct would be easier.
                              3. My girlfriend would ride on that side and she's tiny so no issue and it keeps her warmer and less prone to camplaining.
                              Im not sure how well it would work or the downsides, but something to consider.
