How do we remove them??
Barrel key lock...
Tags: None
On the switch or latch assy, there should be a small (1/16") diameter hole, using a small screwdriver or pin, depress the brass detent on the barrel and it should draw out. (with the key in, of course)Les Parker
Any method to remove the lift gate tumbler without the key? I guess I am asking if that tumbler is interchangeable if I drill it out? My truck didn't come with a key for it and being in the city I'd prefer to have a secure truck._________________________________________
1986 3.5l 110 SW Austrian FeurwehrComment
Haha, Secure and rover are two words I would never put together. The tumbler is the same on the swing away station wagon door as the side doors, but I am unsure about the tailgate options.Bad gas mileage gets you to some of the greatest places on earth.Comment
Quite true, if someone wanted to get in, it wouldn't be that hard even locked. As is now I rely on the lift gate latch being quite hard to turn as the only deterrent. I have a feeling it isn't quite the same as the other latches as I can't see any obvious method of removing the core._________________________________________
Its been a couple of years since I've taken mine apart, and I don't quite remember the details, but you can definitely remove a liftgate tumbler without a key - there is no need to drill it out. It is different than the other tumblers in your truck. In fact, once it is out, you can rekey it to match the other locks or ignition key. When I purchased my liftgate, it didn't come with a key, and I rekeyed it to match the other locks. To do this though, I do remember that the handle need to be removed from the liftgate.
The following is a link on rekeying, I followed these directions and matched all my locks and ignition to 1 key... http://www.tanygraig.force9.co.uk/John/locks.htm'62 109 - coil sprung
'64 88 - coil sprungComment
