transmission swap
R380 has nowhere near the strength of NV4500, and does not have a granny low. The SM420 and NP435 have a granny low and are short, but they are four speeds and have no overdrive. Neither shift as nicely as an NV4500.Well, lots of people still smoke cigarettes even though the evidence of their drawbacks is epic. YMMV The "magic time" for the NV4500 has passed. Nobody puts them in trucks anymore.
It's ridiculously long, and needs adapter$ beyond that to add the transfer case. Won't fit well in SWB vehicles, plus the amount of mods to the interior are insane. It also has a somewhat wussy gear set, when there are 4 speeds like the SM420 and NP435 that have far better crawler gears. With an overdrive you get better gearing with far less length. Better fit is an R380/Lt230.
I never said to use an S3 trans, I wrote that he should not mess with the originals and get a trail rig to wheel.
I totally agree that an NV4500 would be extremely difficult to graft into a SWB Rover. It isn't "ridiculously" long for a 5 speed. It is 3/4" longer than an Aisin AX15, and can be used with a Dana 300 or Atlas II transfer case with NO adapter needed.
Fwiw, my vote was stick with a SIII transmission if using the original engine.
'55 SI 86Comment
Bill,
I have a lot of experience with all of these transmissions. I have had land rovers with each fitted. The NV4500 has a lot of advantages over these others you recommend. I also think there are a few points on which you are mistaken . . .
First the SM420 wont adapt easily to the series transfer case because the casting for reverse is too large. Its a good mate for a lt230 Second, the NP435 is the predecessor to the NV4500. New process and muncie became New Venture (yes the same company you said made lousy stuff, is the one you just recommended . . .twice) Third - The NV4500 sports a 6.34 first gear which is pretty comparable to the four speeds but its fully synchronized. The NV4500 gear set is anything but "wussy". I have zero issues towing 17,000lbs behind a yoked 6bt. Its going on 400,000 miles and shifts perfect.It also has a somewhat wussy gear set, when there are 4 speeds like the SM420 and NP435 that have far better crawler gears.
R380 does fit better, however, it has a laughable 3.39 first gear and a puny gear spread. I've had Milk that lasted longer than R380 synchros. Doesnt belong in the same league with this other stuff.Better fit is an R380/Lt230Comment
'55 SI 86Comment
