I have 1973 Ser 3 88,
There is a rocker type switch on the dashboard, in the center behind the area where the cig. lighter and flasher switch are located. The switch can only be seen if one looks behind this area of the dash, it is not seen looking at the front of the dash. It does appear to be a factory switch.
Also, in the engine compartment, there is porcelain type resister about 1 1/2" long,(similar to the ones used with ign coils.a little smaller) however there is also one mounted near the ign coil. (not connected),
The resister I am asking about is attached to the choke cable, and has a white wires,blue stripes connected. What circuit is this for?
Thanks,
david
Thanks,
david
