Amsoil / Mobil1 / Castrol Syntec
It is my understanding that synthetic oils can have a wider spread in viscosity without the risk of thermal breakdown of the polymers described above. I believe that this is because they are simply more stable throughout any given temperature range.
I have a new engine (under 3000 mi. so far) and plan to run synthetic(probably 5w40 Castrol Syntec) when I hit 3k. My mechanic (I believe everything he tells me) says to break the engine in on the "dino juice" (regular oil).
A change I strongly recommend is synthetic gear oil. A huge change in performance was my experience after making the switch.
One very cold night during a winter in the early 90's I left a bottle of synthetic gear lube (Amsoil, I think - available from our hosts!) and a bottle of standard 90w hypoy out on the porch. It hit -20F that morning. The regular gear oil came out of the bottle like it was rubber cement, but the synthetic seemed little different than when it was warm. I will never run regular hypoy again.
The only problem: It leaks out faster!
I would very much like to hear other opinions about synthetic versus regular oils, especially if you have read of negatives regarding synthetics.
