Ok, first off I am new to rovers. Second I have the green bible. So heres my problem. My right tail light would light up when the key is on, but the light switch is off. I looked at the grounds on the top of the tub, looked ok. Dusty but ok. So I thought perhaps the switch itself maybe be bad, allowing power to pass through to that side. I took the dash plate with the switches off to look around ( lots of wires back there) didn't see anything to out of line, except that they are old. So I decided to leave things alone for the time, and went to start it. I got nada. The headlights dont come on, no power at all. I checked the battery and I have 12.15 volts. Mind you I had zero issues up until I looked into the rear light. Always started with no problem. Now, could I have jarred a wire loose when I put the dash back in? Or are there fuses elsewhere that I am missing. I have two on the firewall that appear to be good. Thank you for any direction you may have.
