Ok, I've read a lot about coolant flush's but I'm still a little unclear as to what the best way of doing this. Should I use a hose? or just a flush product? If I should use the hose method, how do I really do it? Also, what's the best coolant to use once it's been flushed? FYI - first land rover and first car I've even tried to work!
Coolant Flush
There is a drain cock on the side of the block behind your alternator. Open it. Start the truck. Take the radiator cap off and flush with a hose until the water coming out of the side of the block is clear. Shut off the truck and refill with antifreeze in the right proportion.
Rick73 xMOD S3 109
52 M37
