I have a 1959 left hand drive 88 Rover. All the electrical work except for driver side front and rear turn signal. Just replaced with new bulbs, but signal is not working. Switched the bulbs from driver side to passenger side to make sure it was not faulty bulbs, and passenger side works.
For the life of me I can not find the fuse box. I have a voltage regulator attached to bulkhead, to the right of if is a single exposed clear fuse, to the left of the regulator is a black cover that is bolted closed, have not take the cover off as of yet. But it is bolted on pretty securely, can't imagine that it is the fuse box, and it is not readily accessed.
Thanks.
Thanks.
