Just saw it today, get it before it goes away. I love mine.
cheap overdrive !!!
Yep. Sometimes you won't know unless you crack it open, or hear it running. I doubt a seller would let you do that without buying it first.'67 sIIa 88Comment
Cheap buggers...
Lets see....
"Look at it first."... Covered as it is a local seller
" beware cheap ones.".... At 500 , 30 to send to rds , even with 300 in new fitted parts and 30 to ship back , a total of 860 and 2-3 weeks gets you a nice overdrive...new is STILL 1500.....
Any other "sage " advise?Whence came you my brother ? From the East....Comment
i bought mine for 600
had to put 250 into
still totaly worth it.
glad i took a chance
saves my ass for going on 6 hour trips like winter romp.
8 hours without overdrive.
if nothing else youl have something to work with.
i hear the roverdrives are great but 1500 dollars is alot to swallow.
aaron.73 series III 88 2.5 na diesel daily driver
67 series 2a 88 RHD sold
88 RRC sold
60 mga coupeComment
I contacted the seller and it is sold pending funds.
That was a good deal.1968 Poppy Red Series IIA 88" - Mr
1964 Marine Blue Series IIA 109" - Mr Part II
2003 Beluga Black DII - Mrs
1996 Alpine White Disco I - Gone
1996 Beluga Black 4.6L DI - Gone
1992 Eastnor Green RRC SWB - Gone
1991 Eastnor Green RRC Hunter - Gone
1988 Black RRC SWB - GoneComment
Especially equipment that apparently isn't always rebuildable according to the real-life testimonials of folks on the OTHER Fairey thread...--Mark
If the splines are iffy, it's generally advisable to change the clutch and mainshaft together, which will run the north side of $500.
I've just gone through one, replaced all shims to bring the endfloat under .005", replaced the mainshaft and new clutch, yours for $800. I'll even loan you the special socket to get the 'castle sorta nut' off.Comment
I just installed mine and had no trouble getting the nut off..... Maybe I am the lucky one. Of course everything else will fail now.If the splines are iffy, it's generally advisable to change the clutch and mainshaft together, which will run the north side of $500.
I've just gone through one, replaced all shims to bring the endfloat under .005", replaced the mainshaft and new clutch, yours for $800. I'll even loan you the special socket to get the 'castle sorta nut' off.Whence came you my brother ? From the East....Comment
