Pickup cab 109 mounting
  • masonater
    • Nov 2007
    • 329
    I have a PU cab that i have never installed before on my 109. Does anyone have a photo of the brackets that are used to attach the back part of cab to the tub? Any home-made ideas? 4 brackets from RN will run me around 100 bucks. I'd like to think someone out there has a better option. Thanks!
    1970 Series IIA 109 EX-MOD
    1971 Series IIA 109 EX-MOD
    1982 Mercedes 300TD
    1989 RRC
    1993 D110
    1994 RRC LWB
    1995 RRC LWB
    1995 RRC LWB
    1995 Disco
    1996 GMC 2500 Suburban
    1996 Disco
    1997 Disco
    2001 RR P38
    2005 LR3 HSE
    2006 RR HSE
  • antichrist
    • Mar 2009
    • 272
    I've done it with just long bolts.
    Tom Rowe
    62 88 reg
    67 NADA x2
    95 D1 - R380
    95 D90 - R380
    97 D1 - ZF
    • masonater
      • Nov 2007
      • 329
      I can see that bolts will work on the front mounting holes near where your shoulder would be...however along the back egde I dont see any suitable holes that would work with through bolts.
      1982 Mercedes 300TD
      1989 RRC
      1993 D110
      1994 RRC LWB
      1995 RRC LWB
      1995 RRC LWB
      1995 Disco
      1996 Disco
      1997 Disco
      2001 RR P38
      2005 LR3 HSE
      2006 RR HSE
      • disco2hse
        • Jul 2010
        • 451
        What part numbers are you talking about? What four brackets?
        Alan
        109 Stage 1 V8 ex-army FFR
        2005 Disco 2 HSE
        • Firemanshort
          • 282
          Bolts and washers will do it.
          Firemanshort
          1980 Stage One
          • Les Parker
            • May 2006
            • 2020
            I looked at the later Defender brackets (AQU500140), metric fittings, and these are available by Special Order for around $10.00 each.
            FYI.
            Les Parker
            • disco2hse
              • Jul 2010
              • 451
              That's what I did. Still on there
              Alan
              2005 Disco 2 HSE
              • antichrist
                • Mar 2009
                • 272
                This is the proper part number, but you can use bolts
                Britcar Global are the leading supplier of both Land Rover parts and Jaguar parts. We export globally and offer genuine, OEM & aftermarket JLR parts.
                Tom Rowe
                62 88 reg
                67 NADA x2
                95 D1 - R380
                95 D90 - R380
                97 D1 - ZF
                  • 400
                  There are four brackets along the back cab edge. The brackets are just angle with a special bend, with a 5/16-24 threaded nut welded to the bottom of the bracket for the mounting bolt. Two 1/4" bolts with nuts mount the bracket to the bulkhead. If you are handy you could bend some up, or weld a piece of flat stock to an angle to fit.
                  • antichrist
                    • Mar 2009
                    • 272
                    Those are PN 336577.
                    Tom Rowe
                    62 88 reg
                    67 NADA x2
                    95 D1 - R380
                    95 D90 - R380
                    97 D1 - ZF
                    • badvibes
                      • Mar 2007
                      • 364
                      siiirhd88-
                      I also have a truck cab I'm working on. Could you post some basic dimensions for the brackets in your pics? Width of the bracket, measurement for the centers of the 2 bolt holes on the bulkhead, where the 4 brackets are located along the bulkhead? I'm thinking of your suggestion to bend something up, without the nice radius, like you say some stock with the right bends. It'd be nice to have them in the right locations should I run across the original brackets in the future. It does look like a person could fab something workable in the meantime. Thanks. Apology for the hijack.....
                      Jeff
                      1991 Range Rover Hunter
                        • 400
                        Jeff,
                        I'll measure and post the demensions tomorrow. There were dimples in the capping for where the two 1/4 mounting holes are currently located.
                        Originally posted by badvibes
                        siiirhd88-
                        Jeff
                        • Partsman
                          • May 2011
                          • 329
                          Series 2 Club Forum
                          Andy The Landy Shop
                            • 400
                            Jeff,
                            With the end of a tape measure resting on the inside of the body side, the centerline of the outer bracket is at 5 3/8", the centerline of the inner bracket is at 22". The brackets are 2 1/2" wide and about 1 7/8" in height. The centerline of the two mounting holes is 1 3/4".
                            Due to the slope on the face of the capping, the faces of the bracket are not at 90 deg. On my factory brackets the bracket bends forward about 1/2" before being bent backwards to make the flat for the cab to bolt to.
                            I would just bolt the cab in place just behind the doors using the long mounting studs, ensuring the window gaps are set correctly. Once you have the cab where you want it, the location of the four holes on the horizontal flat edge along the cab surface will tell you where the brackets need to be mounted. You need to center your mounting brackets at that point and just fangle your brackets......
                            siiirhd88-
                            Jeff
                            • badvibes
                              • Mar 2007
                              • 364
                              siiirhd88 & partsman-
                              Thanks for the pics and dimensions. I laid the back of the cab top out with the metal plate that mounts between it and the bulkhead, and combined with your info it all seems to make sense now. Thanks!
                              Jeff
