I'm sure you have an answer, but with regard to the L291/292 three screw as opposed to two, the two square knock-outs are for the screws and will line up with holes through the body. Screws originally attached to the L691/692 assembly in a semi-permanent situation. I say semi because I just drilled them out. Screws rusted beyond belief and further use.
Rear lampholder question
Do not forget to check the bulbs themselves. We've noticed that some of the less expensive bulbs of Asian origin have smaller nubs on them, unlike the original Lucas bulbs that have larger and thus more secure nubs to make a better contact with the holder in the lamp base.
