Rear lampholder question
  • Mojave Rover
    • Feb 2008
    • 23
    #16
    Originally posted by transalpian
    Interesting.
    What you have is what I want, I just need to figure out how to get it! I asked an ebay vendor the two- versus three-mounting screw question with no real answer ("I don't have one in front of me"). Maybe I should take a wing on an ebay purchase and if they are two hole, drill the socket to suit the Rover? Not interested in more holes in the body...
    Any thoughts?
    I'm sure you have an answer, but with regard to the L291/292 three screw as opposed to two, the two square knock-outs are for the screws and will line up with holes through the body. Screws originally attached to the L691/692 assembly in a semi-permanent situation. I say semi because I just drilled them out. Screws rusted beyond belief and further use.
    • deezgunz
      • Aug 2011
      • 57
      #17
      fixtures
      the military fixtures are metal with a 3 bolt mounting pattern
      • Les Parker
        • May 2006
        • 2020
        #18
        Do not forget to check the bulbs themselves. We've noticed that some of the less expensive bulbs of Asian origin have smaller nubs on them, unlike the original Lucas bulbs that have larger and thus more secure nubs to make a better contact with the holder in the lamp base.
