Length of pie plate spare tire bolt?
  • knac1234
    • Nov 2010
    • 442
    All,
    One more question I should have asked in my previous thread:
    The pie plate that holds my spare had the part for the padlock for the spare and the "cam" that goes on the other side. The bolt, that screws through the cam into the threaded hole on the pie plate, was missing.
    I have determined it is 1/2-20 thread. Any clue on the length of the bolt needed?
    Regards,
    Julian
    Julian
    72 Series III NAS
    03 Disco
    65 MGB / 73 MGBGT
    71 RHD Hillman Super Imp
  • albersj51
    • May 2010
    • 687
    Julian,
    I'll measure mine tonight if no one responds sooner.
    • knac1234
      • Nov 2010
      • 442
      Thanks Jason....hoping to find one Sunday so I can put the spare on Monday!
      Julian
      Julian
      72 Series III NAS
      03 Disco
      65 MGB / 73 MGBGT
      • Les Parker
        • May 2006
        • 2020
        The ones on my desk measure 2 3/4" from under the head to the tip of the bolt.
        Les Parker
          • 390
          I know there are at least two different length bolts and matching cams, depending on the rim width and offset.
          • siii8873
            • 1013
            these are not just regular bolts. the hex head is larger than a standard bolt, it matches the lug nut size.
            I also thought the threads were a locking type also so they don't loose up.
            THING 1 - 1973 88 SIII - SOLD
            THING 5 - 1958 109 PU
            THING 6 - 1954 86" HT
            • albersj51
              • May 2010
              • 687
              I think its called a Heavy Hex Bolt. I see 1/2-13, but not 1/2-20.
              • siii8873
                • 1013
                1/2-13 in coarse thread and 1/4 - 20 is fine thread. Still the head is not standard for either. It's lug nut size so the spare can be removed with th lug wrench
                • TedW
                  • 887
                  IIRC it's a 1/2" BSF thread. And as stated above, it has a 1 1/16" head to match the lug wrench.
                    I thought I'd need to get a longer hold down bolt when I switched my bonnet spare from 900 x 16 to a 235 85R 16, but the existing hold down bolt with the 1 1/16" hex head is plenty long enough. (Deluxe bonnet with a 109-offset rim)
                    Probably a good thing, since this bolt seems to be a bit exotic...
                    • luckyjoe
                      • 335
                      Mark,
                      Were you running 900x16's or only a large spare?
                      Tom P.
                      1965 exMoD 109
                      1995 RRC LWB w/EAS
                        Originally posted by luckyjoe
                        Mark,
                        Oops--I was confused. I meant to say 7.50 x 16. The 900 x 16's were on my brain from an old military truck I used to own.
                        • knac1234
                          • Nov 2010
                          • 442
                          All,
                          Thanks for the info. I am running the regular 15" rims. As for coarse vs fine vs BSF, the old owner must have tapped the plate for 1/2-20 (as I recall when I tested bolts in there).
                          Did not think about the size of the head. RN PM'd me and told me they sell the right bolt. If it ends up the right thread that mine is, maybe I should order it from them (will have to verify with RN.....I'd hate to spend $20 on a bolt if it does not fit the thread in the hole!!).
                          Back to the rear door.....day off today so it might be on there at the end!
                          Julian
                          Julian
                          72 Series III NAS
                          03 Disco
                          65 MGB / 73 MGBGT
                          • siii8873
                            • 1013
                            I checked one of my bolts. It appears that it is a 1/2 BSF thread.
                            If you would like to borrow one to check for fit let me know.
