Wow, what a puzzle. Your vacuum readings are obviously too low, considering what you've already checked the only other things I can think of is a restricted exhaust (not likely by the looks of your plugs, but it can't hurt to check, the idea is that if you can't exhale, you can't inhale) Another thing to check is valve timing, it's possible that the valve timing has jumped which could result in low vacuum. Other than these two things, I'd start re-checking things again. There's something amiss, just got to find it.
