flickering oil light 95 LWB
  • Ed*
    • 136
    Hi
    My oil light has started flickering when i am at an idle for more than about 45 seconds. This seems to only happen after I've been driving for more than 20 minutes or so. It also only happens when I'm idling. As soon as I drive it goes off and stays off.
    I have checked the oil and it is not low.
    any ideas?
    thanks
  • Firemanshort
    • 282
    rebuild oil pump.
    sounds scary - but not that hard or expensive.
    Just did it for my Stage One (3.5L V8) that had similiar symptoms.
    Firemanshort
    1980 Stage One
    • 57loboy
      • Sep 2007
      • 74
      While the rebuild is not an unreasonable (or difficult)solution, also make sure you're using an appropriate grade oil. My 4.2 has 150k miles on the original pump and I use 15-40 oil. When I redid my heads, I replaced the pressure switch and I only noticed a flicker once since then when I inadvertently let it run a little over a quart low in 90 degree weather...
      '95 RRC LWB (white)
      '95 RRC LWB (Avalon Blue) - sold
      '95 RRC LWB parts truck ready and waiting to donate to the cause...
      • Mike Koch
        RN Sales Team
        • May 2006
        • 82
        Your 1995 RRC oil pump is part of the front timing cover and I don't think it's servicable.
        Mike Koch
        1993 Range Rover SWB
        "Backup car? Why would I need a backup car? My car backs up just fine."
        • Ed*
          • 136
          if it is not serviceable does that mean i just have to replace the whole thing if its dead? this is the 4.2
          • Mike Koch
            RN Sales Team
            • May 2006
            • 82
            Mike Koch
            • Terrys
              • May 2007
              • 1382
              Before you drop serious money on a new front cover, confirm that the pressure is low at hot idle by removing the pressure switch, and putting an oil pressure gage in. These engines do not have GM small block type oil pressures to begin with and the switch diaphragm is known to stiffen with age, triggering it's contact while there's still oil pressure. The new switch is supposed to make contact at or about 4-5psi.
              • Jerry 92RR
                • 20
                Mine started flickering at idle once in a while, too. It will also stay on slightly longer at start-up, more than it ever did in the past.
                This ALL started upon changing the sending unit on the pan. Off roading snapped the wiring on the oem unit so I bought a new one and then the flickering, lagging light, etc. started. I just assumed it was a very sensitive unit compared to the last one.
                Replaced it at about 160k or so and currently sit at 186k. It is also exacerbated by me using 20-50w, (synthetic) blend. I am not worried.
                • wooday
                  • Dec 2007
                  • 51
                  My oil pressure switch has been either steady on or flickering for over a year. At first I was worried, but several visits to my mechanic and follow-on oil pressure tests at oil changes have confirmed that I have good pressure so the culprit seems to be the logic unit. Some days its steady on, others is just flickers randomly - no pattern to it so I ignore it now. I have 230K mi.
                  My mechanic told me that the logic unit is a non-serviceable part so I've just left it as-is. I realize that I won't be able to depend on a dash light to know if I develop a problem, but I just live with the light on all the time. Between that light, the ABS light, and the turn signals my display looks like a Christmas tree or a rasta flag...
                  1975 Series III 88" - SOLD
                  1990 RRC SWB
                  1994 D90 ST
                  2001 Porsche Boxster S
