109 NADA Registry
This is a sticky topic.
It appears it was only running on the first two cylinders... It also had mismatched sparkplugs. Managed to clean the plugs and do a compression test. Results were (front to back): 150, 152, 160, 160, 180 ( that cylinder was full of fuel), 160. I think it sounds good.
One front brake wheel cylinder was seized. I think I will replace all four.
The gearbox wasn't in a good shape. Some remains of a thrust washer fell into the drain pan and the mainshaft had the last 1.5 inch missing... Making the list of the required parts as I continue to discover the various PO modifications that were made...
I do not know yet as I have to see what kind of condition is the engine. It's running, plated and insured. I need to do a compression check and determine if the head is still good. The 109 has 102,000 miles, and has done only 3000 miles in the past 20 years. Chassis was repaired in many places. At least the repairs have been well made.Last edited by michel; 12-31-2019, 06:36 AM.Comment
#453 - Pete Bellas, Santa Clarita, CA - My father purchased it new in 1967, It has been sitting on my ranch for the last 20 years in need of restoration and I hope to get to it this year (2020).Comment
Posted to Guns and Rovers too but might get a better answer here.
I have a NADA 2.6 and my throttle linkage is sticking. I've taken it all apart and done the following:
Cleaned all parts
Replaced the main spring (behind pedal on bulkhead side)
Replaced the bushing on the back of the engine
Lubed and reinstalled everything
When I step on the gas and remove my foot, the pedal returns but the throttle stays on. If I blip the throttle it comes back.
I can't figure it out. I have another friend who is restoring a NADA and his throttle is doing the exact same thing.
Any advice?
ThanksComment
#726 for sale in BC. Has a Chevy engine. I have no connection to the seller. https://classiccars.com/listings/vie...olumbia-v8t4e4Comment
Jack stowage
Question for Jim Chandler (who bought his NADA new):
I assume these trucks came with a Shelly jack, how did they stow it. The tool locker seems the logical place, but how did they keep it from rattling around?
1967 NADA 109 IIa SW
1974 88 IIIComment
Clarence came with a black roll-up tool kit which held several appropriate wrenches and a screwdriver. I wrapped the jack in the roll. Other appropriate maintenance related items were also stowed in the compartment.
JimComment
#411. Delivered to Houston, TX. Purchased from a friend who was a longtime owner. The engine is seized. The transmission, transfer case were missing. It sat in a field in south Bexar County for 20+ years (you can see it on Google Earth 1995-2015). A rebuilt 1992 Range Rover V-8 Rover engine, with fuel injection, and transmission, along with a 2004 D2 LT230 T-case have been installed. Power steering from a P38 is in. New wiring harness, gauges, lights, springs, shock, tires, Series III brakes, exhaust system are in. Several small issues need to be cleared up but mechanically, it's very close to being through. Drove it for the first time yesterday. Brakes suck but I'm spoiled, as I've been driving an RRC for years.
All body seals, the late 1970's installed upholstery and window channels need replacing. I have the repair kit for the door hinges. I also have to replace one alpine window and one pane of the windshield. I wasn't going to repaint it but I'm afraid that when I finally wash it, the last of the paint will rinse off. Almost out of hibernation."Now the company of rogues and cutthroats is complete."
1993 RRC County LWB, Ardennes green
1967 Series IIa 109" NADA Station Wagon Light green
1996 Discovery SE7 Epsom green R.I.P.
#555 lives in Northern Virginia. Rolled off the line in red, now light green with only patches of clear coat left. Bought it in late 18 from Bring a Trailer. Runs well, original engine replaced with an “Iron Duke” (Pontiac I think) motor. Just replaced tires and tire valve stems, next up all the door and roof seals.Comment
NADA Dash
I am not computer literate. I can attach the appropriate pages, in pdf, of the NADA Parts Catalogue which contains a labeled drawing and parts list, to an email if that would be of any help.
Jim Chandler (an original owner) redbrush2@yahoo.comComment
#059
#059 recently acquired from a field in Livermore, Maine. Previous owner apparently purchased from a sell off from ECR . Unsure of plans moving forward as we are currently in the rebuild of a of a 67 5 door diesel.Comment
