It appears your Rover is RHD so you will need a different lever than Les mentioned. I am sure they can get it as when the lever on our 2A 109 broke we got a RHD shift lever from RN for a Series 3 as that is all that was available even then.
Definitely check that grub screw as ours has come loose once. If it has loosened up, try cleaning up the threads and reassembling with just a drop of Purple Loctite (the weakest formula)
